On right click i am getting an error that igfxsrvc.exe has failrd to start because dxgi.dll was not found"
  • 355 Answers
You need to update your copy of windows to get it fixed. Either you can upgrade it from the original cd of widows or from internet directly.
Posted on Apr 02, 2011
  • 192 Answers
It sounds like your video drivers have gotten corrupted somehow. Go to the laptop manufacturers website then go to the support and/or download area. The site should ask you to identify your system through it's serial number, service tag, or similar identification number.
Download the latest driver software for your video chip, and install. Both those files would have been installed as part of the driver package. This should clear up your right-click problem.
Dxgi.dll missing
Here's a whole list of possible fixes (not for the faint of heart!):
http://pcsupport.about.com/od/findbyerrormessage/a/dxgi-dll-not-found-missing-error.htm
Dec 15, 2013 | Microsoft Windows XP Home SP3 for PC
Yahoo chat box blank
*lights cigarette*
You may need to register vbscript.dll and jscript.dll
Follow the instructions below:
1.Run cmd.exe with administrator privileges (Start > type 'cmd' then right click on cmd.exe and select Run as Administrator, then click Continue when prompted by the elevation consent dialogue box). This will open a command prompt in c:\windows\system32
2.Type cd..
3.Type "cd SysWOW64" (Without The Quotes) press Enter
4. Type "regsvr32 vbscript.dll" (Without The Quotes) press Enter
You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
5. Type "regsvr32 jscript.dll" (Without The Quotes) press Enter
You should now get a message that says: "DllRegisterServer in jscript.dll succeeded."
Restart Your Computer.
Now try running Yahoo!
Regards,
Tamim
Jul 21, 2012 | Yahoo Messenger
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Hidserv.exe has generated errors
press start button (the one with the windows logo), then press Run.. and type "cmd" without quotes..
inside the cmd window, tpe chkdsk and wait until it finishes
Sep 16, 2009 | Microsoft Windows 2000 Professional for PC
Spysweeper program damaged after a.exe download
isass.exe is registered as the Optix.Pro virus which carries in it's payload, the ability to disable firewalls and local security protections, and a backdoor capability
How Do You Remove Isass.exe Files in Windows XP and Vista:
  1. Click your Windows Start menu, and from “Search,” click “For Files and Folders….”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a Isass.exe file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop Isass.exe processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys ALT + CTRL + DELETE or CTRL + Shift + ESC.
  3. Click Processes tab, and find Isass.exe processes.
  4. Once you’ve found the Isass.exe processes, right-click them and select “End Process” to kill Isass.exe.
How to remove Isass.exe registry keys: (Do not delete anything other than what is listed below.)
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any Isass.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Isass.exe’s registry keys.
  4. As soon as Isass.exe registry key appears, you can delete the Isass.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Isass.exe DLL files:
  1. First locate Isass.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Isass.exe DLL file is located. If you’re not sure if the Isass.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the Isass.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Isass.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Isass.exe change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Block Isass.exe sites: www.eKerberos.com
Stop Isass.exe processes:
Get rid of Isass.exe DLLs: %PROGRAM_FILES%\ eKerberos\ Hook.dll
Delete Isass.exe folders: %PROGRAM_FILES%\ eKerberos\
Please rate this a fixya
Feb 08, 2009 | Webroot Spy Sweeper (spysweeper) for PC
AegisE5.dll was not found.
hi,
http://www.fix-all-dll-errors.com/aegise5.dll/
u can go to this site...
as I registered few dll's from this site...worked in my case :)
Jan 03, 2009 | Televison & Video
The file bcmwltry.exe is the tray bar process for the Broadcom Corporation Wireless Network software.
You can try eliminating the program from start up.
Click on Start >>Run, type "msconfig" (without the quotes), then click on OK.
When the System Configuration Utility loads, click on the "Start Up" tab, then scroll down to the "bcmwlt.exe" entry and UNCHECK the box next to it.
Click on Apply, then OK, and the computer will need to be restarted. Do it. Upon restart, you'll see a System Configuration Utility warning. Simply choose the option to stop it from repeatedly opening.
This will be fixing your problem
Have a great day!
Pablo :-)
Oct 22, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Legacy
Please try the following:
Click Start >> Run >>
Type the follow command in the Open box.
"net.exe stop wuauserv" (w/o quotes)
Press Ok
Repeat the same for the following commands:
regsvr32.exe wuapi.dll
regsvr32.exe wups.dll
regsvr32.exe wuaueng.dll
regsvr32.exe wucltui.dll
regsvr32.exe MSXML3.dll
regsvr32.exe qmgr.dll
regsvr32.exe qmgrprxy.dll
net.exe start wuauserv
Restart the machine and try again.
May 01, 2008 | Computers & Internet
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
