Question about Rangemaster Classic 90 (Electric) Kitchen Range
The gas flame in the oven of my leisure classic 90 starts on tick over but than does not flare up to full flame like it should
    Problem Solver:
  • 9 Answers
Common problem,it will most probably be the solenoid FF device fitted by the oven burner,these can be obtained from Gas On Spares on 0121-585-7799.the will need the model number and serial number.
Posted on Apr 27, 2011
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Front burner , yellow, flaring flames and sooty pans
Sounds like the front burner gas jet holes are either blocked in places or the gas regulation (air/gas) mix to that burner needs adjusting. Try removing the hub where the gas burns from and cleaning each hole with something like a paperclip and then blowing through it to expel any particals.
Dec 01, 2013 | Rangemaster Classic 90 (Electric) Kitchen...
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
I have a leisure rangemaster 110 double gas oven the left oven stays low i have tried cleaning jets but this has no effect can you suggest a cause
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Dec 18, 2009 | Rangemaster 110 (Gas) Kitchen Range
Both ovens only light to pilot light, wont go
Faulty FFD's ( flame failure devices) once the flame is established it allows the full flow of gas to the burner... must be a gas-safe engineer to replace part..
Dec 17, 2009 | Rangemaster Classic 110 Kitchen Range
Leisure 90 classic
We being US based have no idea on what is in UK SORRY. but quite possibly it has natural gas orfices in it and needs LPG ones
Nov 18, 2017 | Hotpoint RGB526 Gas Kitchen Range
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Rangemaster Classic 90 (Electric) Kitchen Range Logo
626 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
