Question about Dell PowerEdge 1600SC Server
Poweredge 1600sc cant see other 4 drives
I have install windows server 2003. but windows dont see the other 4 hard drives in the case. But in the bios post it see it. How can i get the other drives to work??
  • Coss May 11, 2010
    How do you have the RAID configured?
    And you said the "other 4 drives" how many drive in the box?
    Did you do the install just from the Windows disk? Or did you use the Dell server install disks?
You may have a raid 5 setup. you should be able to confirm this within the raid bios (ctrl+m). if all disks are part of the raid 5 array i believe you will only see this as one virtual disk. a raid 5 array will put the data across all the disks along with parity information. if one disk fails then when you add a replacment disk this parity is used to rebuild your array.
Posted on Aug 28, 2008
HI thanks for reply. i must say im new to this raid stuff. i was given the server by my coworker because he could not get the other drive to show in windows. he got fustrated and gave it to me. so i tey at home. ok here is what i have.
Dell poweredge 1600sc. it has two gig ram. I open the case andther it has one primary hdd and four other hdd connected on one ribbon to the board. it had windows server 2003 all ready on it. I was in the set up (ctrl +m) and i saw the drives say ready. i hit the space bar to set array. after i did that it say i had to initlize it before i reboot. now the drives say online. i boot into windows and the drives are still do not show. am i looking in the right place. i know. im stupid. go ahead and laugh.
plus is there a good place to lean this raid stuff. thanks. nezza
Posted on Aug 05, 2008
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
Dell poweredge 1600sc w/ ATI Mach64 w/ Windows 7 Ultimate highest video mode is 24 bit true color
Bios too old and the 32 Bit system is inadequate to manage the function desired.
Feb 06, 2013 | Dell PowerEdge 1600SC Server
How to install windows server for desktop
You must check if your bios detect your hard disk. check also if you r hard disk is sata and if it is on master jumper. see also it the HDD sata is enable in your bios. if all of this is ok, it must find the HDD. If not, you need to change your HDD.
Feb 09, 2010 | Dell PowerEdge 1600SC Server
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
Backup server
Find the drives on the old server back them up via hard drive or cd/s etc get 2003 windows disc and load in onto new server, then copy over files from old server. Then use a program like nero back it up and have your new server copy all info to old server every week or day.
GOODLUCK!
Dec 13, 2008 | Dell PowerEdge 1600SC Server
Install windows xp pro
Hi
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
http://lsi.com/storage_home/products_home/host_bus_adapters/scsi_hbas/lsiu320/index.html?remote=1&locale=EN
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
victor
Jul 04, 2008 | Dell PowerEdge 1600SC Server
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
Can not access bois
It hangs there probably becuase one or more of the drives are dead or are almost there. Check and see the lights on the drives are falshing funny or too long or are yellow. If you find one of them that are that way, pull it out and then reboot.
See if that helps.
Nov 07, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
320 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
