Question about Hisense LHD3204US 32 in. LCD HDTV
Av 1 and av2
Hi
I have a 37" lcd flat screen tv but i can't find the av buttons on the remote please can you help I need to use my dstv and video.
    Genius:
  • 1,011 Answers
Check its manual in details . u will find that.
regards,
Posted on Aug 05, 2008
How do I put my tv in video mode so I can watch a dvd?
Hi Anonymous,
Please press SOURCE key on the remote, source menu will appear on the screen. Select the source like AV1 or AV2 to which you have connected the DVD player through AV cords.
Happy viewing.
May 31, 2015 | Televison & Video
I have a samsung LCD TV. it shows only AV..I can not use it as AV1 AND AV2
You can select its other 2 av inputs by pressing the AV button on its remote control.
Jan 23, 2013 | Samsung P50HP 50 in. LCD TV
Lg 37lg30 stuck in a loop, it flips between AV2 and DTV1 every 2 seconds. Batteries in remote are fine. Briefly see normal picture when pressing remote buttons before the AV2/DTV1 loop continues. Managed...
Maybe there are buttons on the remote or tv set that are stuck, check these. If no luck then hide the remote so it can't communicate with the set, if it still is acting up unplugg the set for 30 min or more and plug it back in. This may clear a fault that is stuck. If it still is not working correct then the tuner is going bad. Check all devices that are plugged in to the set and unplug them from the tv so the tv does not recognize there is a device connected this may also help.
Sep 24, 2011 | LG 37LG30 37 in. LCD HDTV
Can I set up my older VCR to this TV? If yes how do I get it to work?
Hello
You can surlely connect this TV to your VCR, if the VCR has AV output with it at its rear side. Most VCRs will have this video out from it. Just connect this video out connection to your LGs audio video connection by using an audio video cable. This cable will be of three conductor type and can be bought from most of the electronic sparepart shops at your town. Choose a best quality one, when you buy it. After connectiing this cable with corresponding video IN sockets at the TV, switch ON both the devices and select AV2 or AV1 with the help of remote AV source button. The AV cable will have three conductors, a flat type cable haveing red, white and yellow colured RCA pint at both end. Coincide these colours to both TV and VCR when connecting it. That is all, and you can play your favourite video tapes by VCR.
gopakumarg43_25.jpgThe AV cable will look like this. OK
Aug 27, 2011 | LG 37LC7D 37 in. LCD HDTV
We have a lg, lcd tv.model#37-LD450, we cannot get our DVD player connected so that it plays, any help would be appreciated, owners manual on a dvd and no use
Your dvd will have a scart socket or a hdmi or other socket, ( check manual), connect lead from dvd to tv, output from dvd to input on tv, from one of these ,on your tv remote select the button that changes the av select , that means the button that tells tv that you want to watch signal from dvd ,( or other input devices) ie sky video camera etc it may be av1 av2 av3, you should get a picture on one of these,
hope this helps
pete
Nov 15, 2010 | Televison & Video
AV2 sign won't go away when playing dvd
Press Info/ Display button on TV remote, on-screen display will disappear.
Thanks.
Jan 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When I try to connect a Wii console to my LG television, I put the connection in AV2. But then I get the message that there's no LG signal.
Using the yellow, white and red audio/video cables connect to the side panel of your LG TV and switch the Wii console on. Then press input button on remote and select AV 3 then OK and you should see Wii Menu.
Jan 04, 2010 | LG 37LH30 37 in. LCD HDTV
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
37PF7320A 37 problem hooking up dvd
Connect the DVD to the back of the set on AV2 red white and yellow rca cable . Then to the other end to the DVD red white and yellow. Turn the DVD on and press play. On the tv remote below the number 7 there is an AV button. Press that button and put the tv to AV2. Your DVD picture should be there.
Jul 04, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Hisense LHD3204US 32 in. LCD HDTV Logo
420 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
