Question about Razer Mako 2.1 Speakers
My Razer Mako 2.0 speakers started emitting a ticking (popping?) sound about 2:00 am. My computer was off at the time. The sound is constant unless I turn off the control pad, turn off the sub woofer or unplug one of the speakers. The sound is coming from both of them. I checked all the cables and as far as I can tell they seem to be undamaged. Any thoughts?
  • 2 more comments
  • Anonymous Apr 02, 2011
    If I plug headphones into the control pod I can hear music (sound) but if I remove them I get the popping sound
  • alex_hunter6
    alex_hunter6 Apr 10, 2013
    I know it's quite the thread revival but decided to register to propose my fix to any of you lot who still have their clicky razer makos. I've found the touchpad on the controller to be the issue. For some reason the clicking only starts when the touchpad detects nothing is being pressed and dims its lights. Only way I've found to resolve this issue is to turn the speakers on with the touchpad attached, ramp it up to full volume and prise the touchpad off the controller before clicking ensues. Then control volume with any attached devices. I'm sure I'll find a more permanent fix along the way but it works for the moment! Might give you guys something to go on.
  • fern
    fern Sep 17, 2013
    ok i may have foung a soulation there is a bad diode on the mother bord you may want to pull it out and replace it, i used a meeter to fiend this problem but i bump it insted and the speakers is working good now so-far, any questions drop me am email Flear2004@msn.com
  • fern
    fern Sep 17, 2013
    i will send a image of this fix later.
I guarantee it\'s a simple 99 cent capacitor. takes 5min to fix. It\'s labeled C125 on the circuit board.view this photo for reference....
https://www.dropbox.com/sh/cvlnyj5cmkdr8yl/7tNh8CsSAj#lh:null-Mako.jpg
it\'s a simple 25V 47uf 85C capacitor. you can pick one up at your local Fry\'s electronics, or get one on ebay for about one dollar. I know of 4 people now that have fixed their razer mako with this single capacitor being the only problem. TRUST ME, it\'s not the control pod, nothing to do with it, but the control pod does initiate the power start up, and this capacitor is faulty and works...sort of until complete failure. yet no visual sign of failure with oozing or leaking. it\'s just bad, along with ALL the capacitors on this board are from fujicon... absolute CRAPOLA! make it a project and replace all of them if you want these awesome speakers to last forever. I decided to upgrade it all and bought high end audio caps from ELNA, NICHICON, PANASONIC and FROYLT. Sourced ALL of them on ebay. I\'m not very tech savvy, it\'s NOT difficult to repair one cap on your own. A soldering iron (40watt min) some rosin core solder (thinnest guage is best), and solder wick is all you need. OH, and patience. check this link for more info. https://www.dropbox.com/sh/cvlnyj5cmkdr8yl/7tNh8CsSAj#lh:null-Mako.jpg
I will plan on uploading info about my whole re-capping project, listing all my parts, prices and time involved. Also will post photos of before and after. :D DOOOOO NOT THROW YOUR SPEAKERS AWAY! 99cents is your fix! DON\'T WASTE YOUR MONEY ON NEW SPEAKERS! Razer Mako\'s are amazing speakers, and with an upgrade of new caps, these bad boys are sure to be impressive!
Posted on Sep 27, 2013
  • 2 more comments
  • David Larsen
    David Larsen Oct 02, 2013
    I replaced 25V 47uf 85C capacitor C125 with a 47uF 50v 85C capacitor and it works fine now. I'm curious why you pointed out the other caps as well. And is your plan to replace pretty much ALL components with high end caps, or only the ones you pointed out in your picture?
  • Tim Connor
    Tim Connor Oct 04, 2013
    Those were only pointed out as possible reasons of why the speakers were not powering up properly. And since the board is exclusively FUJICON caps, and know as defective/faulty @ badcaps.net...i decided myself to purchase a full set of audio grade capacitors with matching values. Since replacing caps is fairly easy (i'm not a tech guy) I wanted to make this a fun project. One thing to be sure is to make sure you note if they are polorized/bipolar caps. Many of the in-line audio caps are bipolar (cluster near the line-in 3.5mmjack) and 1 of 2 caps for each 1inch wafer board (6 total) I chose to purchase Nichicon green bipolar Muse caps for these. anyhow, i'm still waiting for many caps to arrive in the mail to complete the upgrade. I'd like to post online my results with photos. If you just want to get these speakers to work, simply replace C125...if the speakers don't work, test the other capacitors that are shown in that photo.
  • Warrior Within
    Warrior Within Nov 02, 2013
    Greetings, any progress on that parts list Tim?
  • Ryan Christie
    Ryan Christie Nov 14, 2013
    From what Tim has said I opened mine up and swapped the C125 with C65 for a quick fix, and it worked. I have caps on order to replace all the 47uF 25V caps.
I can tell you that the problem is not the fuse. I also randomly received the Razer Mako popping sound of death a couple weeks ago and replaced the fuse in the subwoofer. This did not resolve the popping noise. Essentially you need a new subwoofer from Razer. Unfortunately the product is discontinued and Razer's customer support is less than helpful. I would recommend saving up for some new speakers. Maybe you should get a pair of Audioengine A5s like I did. Anyway, my condolences for your loss.
Posted on Jul 09, 2011
I have followed this manual with great success too. My Mako soundsystem works like a breeze again...:-)
Posted on Jan 05, 2016
  • Quang Phm
    Quang Phm Apr 14, 2016
    Hey man can you show the photo of your razer motherboard ?
Posted on Apr 11, 2013
  • 4 Answers
Testing its not posting.
Posted on Feb 15, 2013
  • lxs45 Feb 15, 2013
    My mistake on the post / reply. So I have the same problem as you guys. Power on the speakers, and clicking starts. All within 2 years and felt like $300 down the drain. I also seek answers but couldn't find any. I found a solution and speakers have been working 3 days as of this post. Question.. is oxydation and crud built up on the underside of the main board? Answer ... clean up oxydation with acetone. Corrosion on electronic contacts can dramatically impact the performance of a device, which may become inoperable if the corrosion clogs the power contacts to the point the electrical circuit is broken. Oxidation of metal parts because of humidity and old, leaking batteries is a common cause of corrosion. Oxidation is evident from the distinctive pale green film that develops on contacts.
Ive opened up the control panel a couple of times and messed around making sure all the connections are there. that fixed it most of the time but anytime the power goes off unexpectedly, clicking comes back. good luck
Posted on Oct 25, 2012
Ditto to Pulp088 Jul 09, 2011. Exact same thing happened to me about 6 months ago. Razer's support was useless and I had to scrap the speakers, which were operational for only about 2 years and being used in an office setting, never saw hard use.
Posted on May 24, 2012
Sundenly my speakers don't have a sound technition checked for 2 hours and can't find whats wrong
depending on the operating system open sound in control panel and select the speakers if they are shown and right click and set to default, ensure the check box for "all devices currently playing sound is ticked" if this isnt working try pluging the speaker into an ipod to ensure theve not popped.
Jan 29, 2013 | Dell A215 Computer Speakers
Makes a clicking sound and won't play sound
I guarantee it's a simple 99 cent capacitor. takes 5min to fix. It's labeled C125 on the circuit board.view this photo for reference....
it's a simple 25V 47uf 85C capacitor. you can pick one up at your local Fry's electronics, or get one on ebay for about one dollar. I know of 4 people now that have fixed their razer mako with this single capacitor being the only problem. TRUST ME, it's not the control pod, nothing to do with it, but the control pod does initiate the power start up, and this capacitor is faulty and works...sort of until complete failure. yet no visual sign of failure with oozing or leaking. it's just bad, along with ALL the capacitors on this board are from fujicon... absolute *******! make it a project and replace all of them if you want these awesome speakers to last forever. I decided to upgrade it all and bought high end audio caps from ELNA, NICHICON, PANASONIC and FROYLT. Sourced ALL of them on ebay. I'm not very tech savvy, it's NOT difficult to repair one cap on your own. A soldering iron (40watt min) some rosin core solder (thinnest guage is best), and solder wick is all you need. OH, and patience. check this link for more info. https://www.dropbox.com/sh/cvlnyj5cmkdr8yl/7tNh8CsSAj#lh:null-Mako.jpg
I will plan on uploading info about my whole re-capping project, listing all my parts, prices and time involved. Also will post photos of before and after. :D DOOOOO NOT THROW YOUR SPEAKERS AWAY! 99cents is your fix! DON'T WASTE YOUR MONEY ON NEW SPEAKERS! Razer Mako's are amazing speakers, and with an upgrade of new caps, these bad boys are sure to be impressive!
Jan 27, 2013 | Razer Mako 2.1 Speakers
I want to off the microphone of this speaker but I don't know how. The speaker emits a sound like that of a microphone and it disturbs our listening to music.
if you want to off the microphone
click start control panel sounds and audio devices select advanced there you can a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has or has'nt got a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has'nt a tick in it
click start control panel sounds and audio devices select advanced there might not be a tick in the mute box tick it although it should not interfere with any listening to your music there might be another issue
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 26, 2011 | Altec Lansing VS2421 2.1 Speakers
Where can I get a new control pod from for razer mako 2.1. Or where can you get it fixed in the UK?
The solution is that there are two capacitors in the subwoofer amp that need replacing. A qualified electrical repair shop can do this easily for you. If they put it on the oscilloscope, you'll see that the issue is one of two caps :
Best solution is to replace both the capacitors. One capacitor is 47 uF/50V, and the other is capacitor is a 100 uF 35V.
Voltage (Voltage capacitors) must be of higher capacity, not lower. By putting in slightly bigger capacitors, it will more resilient to dirty power, which I believe is the reason why it went bad in the first place - put these on a proper power surge/filter to protect them.
May 14, 2011 | Razer Mako 2.1 Speakers
Hi I bought Razer Mako speakers few days ago, and from the start i've got this problem... The speakers stop working (there's no sound) after few minutes (from 7 to 15) of playing, the same for different...
I had the same problem today. Don't know what caused it. But I turned off the Makos using the switch behind the subwoofer waited about a minute then turned them back on, problem solved.
Hope this helps you and others who encounter this problem.
Sep 07, 2010 | Razer Mako 2.1 Speakers
TEKK 2 treadmill motor problems
You lower computer board is bad. are they still in business?? If not it will be time for a NEW treadmill. name brand so we can get parts
Apr 06, 2009 | TEKK Fitness Two Treadmill
Left computer speaker is unpredictable
Take no offense but after 8 years, you got your moneys worth. Unless you're good with the soldering iron and schematics, call it a great investment and update your speaker system. I imagine your computer is newer than the speakers and you can take advantage of some 5.1 surround sound! It's really great if you do any gaming,too.
Since you'll probably be getting rid of them anyway, you might want to crack it open and see if there's any loose wiring that can be fixed.
Thanks for using Fixya.com. Please rate this tip accordingly. I wish there was a better solution but I usually get 5 years out of mine so I feel jealous. :-)
Jan 11, 2009 | Harman Kardon HK695 Computer Speakers
Bose Companion 5 Producing Unstable Sound
The intensive bass is making the speaker shake very much and that could have caused a short that changes the volume after a while when the speaker has been shaking for a period of time. You could try lowering the bass or volume to see if it makes a change in how long it takes to make the volume change.
Oct 18, 2008 | Audio Players & Recorders
Razer Mako 2.1 Speakers Logo
5,045 people viewed this question
Top Razer Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Razer Audio Player and Recorder Expert? Answer questions, earn points and help others
