Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes do not spin and not sucking up water - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
SOURCE: Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 02, 2008
  • 294 Answers
SOURCE: Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Posted on Jan 19, 2009
SOURCE: Hoover steam carpet cleaner brushes dont spin
There is a plastic cover over the spinner indicator. If you take the plastic cover off there is also a little filter in that area (almost like the spinner is on the floor and the filter is on the wall). If you clean this filter it may start working again. I had the same problem before and it worked for me. I found the info in the user's manual for my model. Hope this works for you as well.
Posted on Sep 04, 2009
SOURCE: Brushes do not spin on my steam vac
We were having the same problem with the brushes not spinning.
How I fixed it:
I Removed the brush assembly by gently pulling on both sides of the assembly. I took a wide slotted screwdriver and inserted it into the slot (hole) that turns the brushes. At first it did not want to move. I GENTLY applied pressure by turning the screwdriver to get the gear to move and it began to move freely. I spun the gear a number of times using the screwdriver to make sure it was moving freely.
I reinstalled the brush assembly by aligning the gear that slides into the slot and gently pushing the clips back into place using equal pressure on both sides.
I plugged in the machine and the brushes now spin!
Good luck to everyone out there!
Posted on Oct 17, 2009
SOURCE: steam vac will not pick up dirty water
I had the problem with not picking up the dirty water. I fixed the lid to the receiving tank and it worked fine. Phew!
Posted on Jun 30, 2010
Why aren't brushes spinning?
Belt misalignment sounds like the problem
Mar 31, 2016 | Dyson DC59 Animal Bagless Cordless Stick...
Why wont the brushes spin? I have had this machine for about 3 years and it has always worked great, tonight the brushes will not spin at all, it still sprays and sucks up the water. We took the brushes...
In this machine there is no belt. The brushes actually spin by vacuum and in the turbine assembly there is a small wheel bearign which rusts out. You will need to remove and repair or replace the turbine and gear assembly P/N should be 43191009
Feb 10, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Sep 03, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
The spin brush wont spin but the water is spraying out and sucking up
possibly the brushes need cleaning http://www.hoover.com/pdfs/manuals/F5914900.pdf manual for your steamvac
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Jan 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes will not spin
There is a motor for the brushes, it may be bad. If no suction, there is a gasket on top of the back cover that may be missing leaving a gap and losing suction.
Apr 18, 2008 | Bissell 1699 ProHeat Clear View Upright...
How I fixed it:
Jan 21, 2008 | Hoover F7222-900 SteamVac Upright Vacuum
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
59 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
