Question about Panasonic CQ-C7103U CD Player
Where do u hook up aux? - Panasonic CQ-C7103U CD Player
How do I hook up Roku 3 to my television?
hook the RCA cables to the "input" on the tv and switch your tv to the setting for "aux" (you may have multiple aux inputs like 1 and 2) make sure setting is on aux 1 if cables plugged into aux 1 etc. then put in the ssin numbers fron your router and password then you should be up and running. sometimes you have to set your router to not be password protected and not use a password.
Dec 09, 2014 | Roku Televison & Video
Hook up a yamaha htr5840 to a nikko eq-1
generally an equlizer hooks up to the amp auxilary- if the amp has auxilary at the back.then hook up devices to the equalizer.
hook up red and white wires to equalizer output and the other end to amp aux red and white holes at the back of the amp then turn nob on amp to aux.If you dont have aux then try tape function
Dec 07, 2013 | Audio Players & Recorders
Samsung ht-c653w will not give me any sound at all from my digital audio in or my a/v input. (trying to hook up my ps3) But when I hook up the hdmi, the audio is fine for any dvds I play. think it's...
Have you selected the AUX IN?
AUX2 : Connecting an External Analog Component
Analog signal components such as a VCR.
Connect AUX IN 2 (Audio) on the back of the product to the Audio Out of the external Analog component.
Be sure to match the colors of the connecting jacks.
Press the FUNCTION button to select AUX 2 input.
The mode switches as follows :
DVD/CD ? D.IN ? AUX 1 ? AUX 2 ? USB ? IPOD ? FM.
Jun 05, 2011 | Audio Players & Recorders
HOW DO I HOOK UP AN IPOD TO A CD MIX2 , i hooked it into the aux on the back, i didnt get no sound evevrything was hooked up ,
You would need a Stereo jack to RCA cable. Input into Aux channel in rear, make sure your switch on faceplate is set to Aux. You may also need to turn up volume on the ipod.
Dec 07, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
How do i get the sound from my tv to come throud the ilive bar
Check the users manual for your boombox. Look for information on AUX inputs to the boombox. If there is a way to hook up your tv using AUX inputs it will guide you through the process. For example this boombox by Altec does allow you to hook up AUX equiptment like a tv. CLICK HERE TO SEE IT!
I hope this helps you in yout quest!
Nov 11, 2009 | Apple Audio Players & Recorders
Can I add a phono player to this receiver? I have the manual for this receiver and think I need to hook it up to AUX, is that right?
Yes, you can hook it to AUX, it is really doesn't make much difference if you hook it to CD in or TAPE in or AUX, just press corresponding button in the front :)
Oct 31, 2009 | Sony STR-DE545 Receiver
Auxillery in question
yes you can hook up your mp3 to an aux input on a stereo not sure what you mean by converter typically it is done through a 3.5mm - 3.5mm standard audio cable. and in order to do this your reciever must have an aux input of course and if so then you can toggle the mode of input by pressing the Mode or button that switches from radio to cd etc or consult with your users manual to find out how to switch and if aux input method is supported
Feb 15, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Panasonic CQ-C7103U CD Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
