Question about Medion MD1777 (MD1777C67) PC Desktop
SWITCHED OFF COMPUTER AND NOW IT WON'T START, NOTHING AT ALL
    Problem Solver:
  • 19 Answers
Try completely dismantling it and put it back together disconnect the power suply from the motherboard and remove the button battery replace everything where you removed it if no go then its dead
Posted on Apr 02, 2011
Won;t start nothing works except lights and beeping sound when door is open where is the starter located
Do you know how to do electrical testing ? Engine Won Start No Crank Diagnosis Troubleshooting Starting System Issues No Crank Troubleshooting engine does not crank The starter is under the vehicle bolted to the bottom of the engine ,most usually > Some car makers hide it under the intake manifold in what is referred to as the valley on V - engines . The way modern vehicles are the starting system is computer controlled . A relay is a switch controlled by the PCM - engine computer .
Nov 15, 2015 | 2008 Dodge Charger
When I try to start my spyder sts-se5 I turn the switch and nothing happening, its as if their is no power, no light or nothing. Can you help?
Hi, Sarah and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
Spyder won start Can Am Spyder Forums The factor Community
Thread Won Start won turn over
2014 CanAm Spyder RT Series Repair Maintenance Parts Master Collection...
Can Am OEM Parts
http://www.spyderlovers.com/RT/NEW2010RT.pdf
Sep 15, 2013 | CanAm Motorcycles
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
see this causes and fix it. God bless you
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Sep 28, 2012 | Washing Machines
Car won't start
A mechanic would check for voltage at the starter, the neutral safety switch, and the key switch. Also check the ground connections.
Jul 30, 2012 | 1991 Plymouth Acclaim
06 trailblazer trouble with anti theft system, I think, starts right up then other times the anti theft light comes on and it won't start. can try it 2-4 hours later and it starts right up????
The first thing to do get it checked for DTC'S - diagnostic trouble codes . Not at auto zone or any other parts store , you want to have full scan of all the modules on the car. Don't know how much you know about automotive electronics , computer controlled systems etc.... Your vehicle has at least 10 modules (computers ) on board , there all talk to each other on a serial data network . C.A.N - controller area network . Or in the case of GM it has it's own . GMLAN -
How to Diagnose Controller Area Network CAN When you turn that ignition switch to start it is an input to the computer ,be it the PCM or BCM ..
Jul 01, 2017 | 2004 Chevrolet TrailBlazer
Kitchenaid kudi01ilwh2 won't start
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Nov 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Lexus gs400 1998 ignition switch turned all the way to the start position, occasionally nothing happens won't start. Battery checked OK, cables clean and secured to battery terminals, headlights work....
Sounds to me like either an Immobilisor or Key transponder issue.
Have your vehicle's OBD2 body computer checked for diagnostic codes by your nearest authorised agent - 90% of faults are monitored by this computer.
Checking for codes only takes 15mins (providing the technician knows what he is doing) and will save you unecessary expense.
Cheers,
Aug 28, 2011 | Ignition System for Lexus GS400
Medion MD1777 (MD1777C67) PC Desktop Logo
80 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
