Question about GE Profile DPSR475EW Dryer
The belt on dryer sweeks - GE Profile DPSR475EW Dryer
    President:
  • 2,468 Answers
Its probably not the belt,rather the idler tensioner pulley that keeps the drum belt taught to turn the drum,replace both as long as you have to tear it down anyway part numbers are belt AP4324040 / tensioner idler pulley AP2043227 available from appliance parts pros 1-877-477-7278
Posted on Apr 02, 2011
I have a 2003 escape and it runs but its sweeking when you hit the gas it also has loss of power it only goes up to 25mph and starts sweeking
my 03 escape has a clogged cat but there is 3 of them is there an easy way to find out witch 1 it is
Sep 29, 2012 | 2003 Ford Escape
I changed the alternator on my 99 alero an now it makes a loud sweeking niose is there a way to tighten the belt
LOOSE BELT MORE LIKELY YOU HAVE A BAD BELT TENSIONER.A BAD BELT TENSIONER WILL CAUSE BELT TO SLIP.WHEN THAT HAPPENS ALTERNATOR CANT SPIN FAST ENOUGH TO KEEP BATTERY CHARGE.AND IF YOUR WATER PUMP DONT SPIN FAST ENOUGH ENGINE WILL OVERHEAT AND YOU WILL HAVE POWER STEERING PROBLEMS ALSO HAVE DRIVE BELT TENSIONER CHECK OUT AT A GARAGE..
Aug 30, 2011 | 1999 Oldsmobile Alero
Dryer makes loud sweeking noise sometimes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Frigidaire Electric Dryer
I have a 1999 oldsmobile cutlass and the gas gauge doesn't work and it has the loud sweeking sound when i crank my car up and then it stops when the car warm up, i jus put a brand new belt on my car! what...
Try some bar soap on the belt before you start it for the squeal it is the alternator pulley or bearing. The alternator is trying to recharge the power back in to the battery that you used to start the car. So the belt slips on the pulley.
Feb 01, 2011 | 1999 GMC Yukon
It makes a sweeke sound
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes squicky noise while drying
its the drum glides/slides that support the front part of the drum open the door and push on the door switch and start the dryer and you will be able to locate the noise source easily
Squeeking noise when car starts in the morning, when it's cold.
it sounds like it your belts are slipping check adjustments if it has any not sure on this car if the belts are tight you can buy spray from a auto shop to stop the noise hope it helps
Dec 30, 2008 | 1994 Mercedes-Benz C-Class
Loud sweeking noise at start, when cold outsides
most likely your alternator, when it is cold and you start the alternator needs to recharge a heavy discharge, bearings or slip ring worn. also check the drive belt for wear,
Nov 24, 2008 | 1994 Mercedes-Benz C-Class
Dryers Logo
132 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
