Question about Lexmark Office Equipment & Supplies
Hi. I have previously downloaded the driver for the Lexmark X75 printer, but when I try to print -I get the following error message: "Incorrect Port Detected. The current print job has been canceled. The printer is designed to to work with USB cables only. The current software setting is not set to USB port. Make sure: -You are using a USB cable. -The printer is set to a USB port." I am using a USB cable. I go to my Device Manager, and under Universal Serial Bus Controllers is Intel(R)82371AB/EB PCI To USB Universal Host Controller Is my port enabled? What should I do ? Thks
  • 39 Answers
I'm assuming you're using Windows XP. If not, these directions may differ a little.
  1. Click Start > Printers and Faxes.
  2. Right-click on Lexmark X75, and then click on Properties.
  3. Click on the Ports tab.
  4. Find Lexmark X75 under the Printers column (or look for which item under the Port column is checked).
  5. Chances are it somehow got changed to COM or LPT. Find any available USB port and check it. Click Apply.
  6. Try to print. If it doesn't work now, you'll probably get a different error, something like "Cannot Communicate". If that happens, go back to theProperties window and try checking any other USB ports you see there. If there aren't any more to try, you may have to uninstall and reinstall the drivers to get it working.
Posted on Aug 07, 2008
  • Russ Robbins
    Russ Robbins Aug 08, 2008
    Hi, did you have any luck fixing this?
Printer won't work with HP WIndows 7
I regret to inform you that the Lexmark X75 does not support Windows 7. It works on Windows XP and previous versions.
You may contact Lexmark Technical Support Center to check for other options.
Feb 20, 2012 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75.........computer can read the scanner but not the printer
Please ensure that the Lexmark X75 printer driver is properly installed on your computer. You can download and install the X75 printer driver by visiting the Lexmark website at http://bit.ly/iSpJjv. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Note: The Lexmark X75 printer is not compatible with Vista and Windows 7.
Jun 15, 2011 | Lexmark X75 All-In-One InkJet Printer
I lost my soft ware for my printer lexmark x75 and i can seem to conect to my computer i try everything
You can download the software at lexmark.com. Try re-installing it and following the promps. Hopefully you'll be able to print again.
Mar 19, 2011 | Lexmark X75 All-In-One InkJet Printer
Require 64 bits driver for Lexmark X75 for windows vista
please copy the following address in the address bar of your browser and you can download the drivers,
http://dfinder.bluesquad.revenuewire.net/dg-pro/download
or
you can visit the following link address
http://driversfinder.net/drivers/lexmark-x75-vista
Jan 10, 2011 | Lexmark X75 MF All-In-One InkJet Printer
Lost disc to lexmark x75 printer. downloaded driver from lexmark website. asking for file 'LXBBDR5C.DLL' lexmark inkjet driver installation disk when i try to print. do not have the disc - where can I find...
Hi there It is the driver may have not got the DLL files in it could be missing if you want to try again,
You can download a driver Software from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the Lexmark-X75-XP.exe Printer and will work for XP.
Link= http://www.4all2sell.com/driver/Lexmark-X75-XP.exe
Ones you have downloaded just double click and it will take you through the installing
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 19, 2010 | Lexmark X75 All-In-One InkJet Printer
Vista does not recognize my printer
Unfortunately you did not provide much detail about your problem, but I will do my best to help you.
The most likely issue is that you do not have the required drivers for it.
After going through Lexmark's site, it seems that they do not have a Vista driver for your printer. However, you can try to use the XP driver at this link:
http://support.lexmark.com/index?page=answers&startover=y&question=X75+drivers&locale=en&productCode=LEXMARK_X75&segment=DOWNLOAD&userlocale=EN_US+#2
From there, click the downloads tab below the image and download the XP driver.
The possible alternative to that would be to see if Windows Update will provide a driver, which is what they occasionally do for some hardware.
Hope I was of assistance :)
Nov 28, 2009 | Lexmark X75 All-In-One InkJet Printer
Can't get my lexmark x75 to print on mac os10.4
Here is the link for the 10.2 and 10.4 driver you need. Download the correct driver and install it.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Feb 27, 2009 | Lexmark X75 All-In-One InkJet Printer
Lemark x75 doesn't print with vista os
Hello Jean,
Its the drivers alright. Pretty frustrating too.
Lexmark has not released Vista drivers for many of their older printers, including the X75. It won't work.
Sorry, just don't shoot the messenger.
Mike
Aug 12, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 poor faxes
first download this, it will clean up the previous installed drivers
then download this, put fresh drivers on computer
Jun 29, 2008 | Lexmark X75 All-In-One InkJet Printer
X75 Printer
download the driver from the lexmark website and install it in your computer, follow all instruction and you are on your way to go.
Dec 09, 2007 | Lexmark PrinTrio X75 Printer
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
