Question about Rowenta Vacuums
I have an old Rowenta. To fill, which way do I push the red and blue side button and to have steam and spray which button on the top do I use, red or blue?
3 Suggested Answers
informatica
  • 1114 Answers
SOURCE: Black & Decker SV1000-4 SteamBuster Vacuum
You can download the manual from the link below: http://www.dewaltservicenet.com/ServiceNet/Logon.asp You will need to register but it's free. As you know there's not much to the spray function but you should hear a pump running when you push the switch. You may need to clean the dirt bowl & filter for better results this is described in the manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
Your pump probably needs to be cleaned after sitting so long unused the piston can get stuck.
Open it up and disassemble the pump clean the piston and make sure it moves well in the cylinder reassemble and it should now work.
Posted on Jul 23, 2008
I'm not able to release the steam head. I push the button but it will not release.
You will have to take the trigger mechanism apart as the catch has jammed. If it's less than a year old, take it back and get a new one under warranty.
May 13, 2015 | Shark Rotator Vac-or-steam 2-in-1 Hepa...
I fill the reservoir before beginning ironing and after I finish ironing there is almost the same amoount of water left in the resevoir. The only time I can spray water is when I press one of the spray...
Hi nananmm,
Try flushing the iron and clearing the holes by filling the iron with a mixture of half white vinegar and half water. Set it for steam and let it sit on an old cloth for about 30 minutes.
This should flush out any buildup in the iron and holes.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 13, 2011 | Vacuums
Rowenta Effective DX 1700 model---won't spray water?!
Mine was getting slow to steam, downloaded a manual (could only find model #1900, but close enough), and found out how to clean- fill with water, heat to the highest temp, hold over the sink horizontally and hold the steam lever over to the "self clean" position for one minute. That's supposed to purge the system of junk. Manual site: http://dl.owneriq.net/2/28c59722-2a7e-45ae-b333-c20240d7e9f5.pdf It's a free download.
Dec 29, 2010 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
I have a bissell pro heat water wont come out
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
May 29, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell 9400 pro heat steam cleaners sprayers are clogged again...how can I fix this with out taking it to a shop to get fixed?
Nov 05, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Vacuums Logo
13 people viewed this question
Top Rowenta Vacuums Experts
Charles T Nevin
Charles T Nevin
Are you a Rowenta Vacuum Expert? Answer questions, earn points and help others
