Question about Kitchen Ranges
My Whirlpool Model # WFW9300VU02 front load washer will not even turn on. Its plugged into a threeway outlet with a light fixture bulb maybe using a forty watt bulb. The light still stays lit while the washer machine will not turn on..? I tried swithing the plugs around with no luck and the light works in both top & bottom plug ins. My wife unplugged the machine because ther was a rain storm and when she plugged the cord back in there was crackling ete. the light still works in both top and bottom.
  • 9 Answers
SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Posted on Mar 11, 2008
  • 2651 Answers
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
Posted on Mar 17, 2008
  • 489 Answers
It sounds like a problem with the control board.  You will need to have the unit checked out by a qualified LG technician and possibly replace the board.
Posted on Sep 29, 2008
  • 750 Answers
SOURCE: oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Please remember to leave a rating!
Posted on Oct 16, 2008
  • 126 Answers
SOURCE: Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Posted on Jan 15, 2009
Duet Washer Won't Start; Outlet Fine
How old are they & where did you get them from?
Jan 30, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washer brand new will not spin dry about every 3rd. load.
make sure you use it well by following the knobs or setting or check the knob maybe its not proper indicated or check the back hardware maybe something is not plug.
Apr 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Waher will not turn on--no lights..nothing..outlet has power and water is connected. i washed loads last night.
We are experiencing a similar problem with our Bosch 500. The plug shows hot. I pulled out the plug and tested the wires, also shows hot. Our interim solution is to use an extension cord and plug into another outlet. So far so good. I wonder if the problem is upstream, maybe a weak breaker? We will be calling an electrician.
May 06, 2010 | LG WM-2277HW Front Load Washer
Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
also check out this link for more help
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
46462 unit will not turn on
Hello anava214
You said, your washer will not power up . Even the lights on the display panel are not turning on . And you have checked that the power outlet works.
Did you unplug the washer for 5 minutes and then plug it back in?
This can resets the system.
How old is the washer?
Oct 05, 2008 | Kenmore 46462 Front Load Washer
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
