Question about Sierra Mercury/Mariner Power Trim Relays
Hi I am trying to connect a Schrack RP420006 relay to a small 4.5-15v DC motor in order to change rotational direction of motor as required. Any help will be much appreciated.
  • 8,269 Answers
Hi, here is a way to wire this. Please let me know if you have questions, and thanks for using FixYa.
Posted on Apr 02, 2011
  • patrick_mcco Apr 03, 2011
    Hi jtercotte many thanks for the quick reply,Just one further question,
    am I correct in thinking that this arrangement requires two seperate power supplies
    or am i misreading your diagram ?? Many thanks again Great help so far
  • Jeff Turcotte
    Jeff Turcotte Apr 03, 2011
    Hi, that depends on the motor power supply you are using. The relay coil runs on 6 VDC. If you can pull a 6VDC signal from the motor power supply, then you can get by with the one source. Can you tell me about the motor power supply, or have you not selected one yet? If the power supply has a higher DC output, it may be a simple matter of using a resistor inline to the switch to allow it to power the relay coil without burning it up.
How to clear E000051-0000 in IR3300 Photocopy Machine
E051-0000- At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main Cause- The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO:Connect the connectors.
2. Sensor lever (damage and interference),
Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES:
a. The horizontal registration assembly is out of place because of damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty.
Replace the motor.
NO: Replace the DC controller PCB.
Aug 17, 2016 | Canon IR 3300 Digital Copier
How can I fix an error code E007 on a canon IR2022 copier?
E007
0000-
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Main cause-
The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution-
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Wiring
Are the wring and the connectors connected securely?
DC controller PCB (J311) <-> relay connector <-> fixing film sensor
NO:Connect the wiring and the connectors.
2. Fixing film sensor
Check the fixing film rotation signal.When the fixing motor is rotating, is
the film rotation detection signal sent by the fixing film sensor to the
concoctor J311 of the DC controller PCB?
Film rotation detection signal:5V pulse signal between J311-A9
(FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440 msec OFF
NO:If the fixing film is normal, replace the sensor.
3. Fixing film unit, DC controller PCB
Is there a fault in the fixing film edge rotation detection mechanism?
YES:Replace the fixing film unit.
NO:Replace the DC controller PCB.
Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*)
Try this - Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Jul 16, 2014 | Canon iR 2022 Printer
Why would my belt on the Proform 730 si begin to run backwards? Does anyone know the fix for this issue?
If it was running in the proper direction before suddenly changing the direction then the motor control board is faulty. If it was happened after some service inside then the connection of the motor is reversed unknowingly. If so reverse the connection of the motor. As its a DC motor it will change the direction when the applied DC voltage reversed.
Ajin
Nov 03, 2012 | Proform Exercise & Fitness
My IR 3300 display E000051-0000 please help me...
E051
0000 At start-up, home position is not detected when the horizontal registration
Main cause The horizontal home position sensor is faulty. The horizontal registration
Action
1. Connector
a. DC controller PCB (J304) relay connector horizontal registration
b. DC controller PCB (J304) relay connector horizontal registration
motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
YES: a. The horizontal registration assembly is out of place because of
sensor.
PCB?
YES: The horizontal registration motor is faulty. Replace the motor.
As You can see, is better to call service.
Hope that helps!
Aug 01, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Hobart slicer 2912. The slicer works fine on manual but the automatic mode has stopped working. thinking it may be the motor but not sure,,, any idea on how to identify the part that needs changing?
HI. Have you tried checking if you can hear the motor is rotating. There are actually gears connecting the motor to the blade.The motor on it is just a dc motor.voltage usually ranges from 20 to 50 volts dc.If you can removed the cover and check if the motor is rotating while the unit is plugged on though this is not advisable to do this but for the sake of observation and making sure that while doing this you haven't touched any of its auxillary parts.Try to check how the gears are moving..Hope this helps.Thank you for choosing FIXYA.
Jul 18, 2011 | Microwave Ovens
E000007-0000 errorquick solution in IR 2200 Canon printer
Fixing film rotation error
The reading of the main thermistor is 100°C or higher and, in addition, the
Main cause: The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution: To clear the error, execute the following in service mode:
Action
1. Wiring
NO: Connect the wiring and the connectors.
Film rotation detection signal: 5V pulse signal between J311-A9
msec OFF
NO: If the fixing film is normal, replace the sensor.
YES: Replace the fixing film unit.
Jan 27, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Have a 1992 Ford Bronco Eddie Bauer Tailgate window motor problem
I looked at my schematics, and they don't show a relay. They do, however, show two ground wires coming out of the tailgate window switch. There is a ground wire for the "up" side of the switch, and a ground wire for the "down"side. These would be color-coded black, and I think that it is worth checking to make sure you don't have a corroded /broken ground running from the tailgate switch. If only one grounding wire was broken, the window would operate in only one direction. Both dash and tailgate switches share the same wiring circuit, and these wires are "hot" all the time. It's normal when you get both sides of the motor leads at 12VDC when neither switch is activated. These switches function by switching off one of the two motor leads, and connecting it to ground, thus allowing power to flow thru the motor windings. Of course, reversing the polarity on a DC motor will change the direction of rotation, so changing which black lead is switched to ground gives the up or down direction to the motor.. since you can read schematics, you might check out ebay for a used Haynes manual cheap. hope this helps
Apr 29, 2010 | 1992 Ford Bronco
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
sensor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Replacement motor
You can identify rotation direction of the motor and order one from this site
http://www.studiosoundelectronics.com/cassette.htm
Apr 10, 2009 | Denon DRM-555 Dual Cassette Deck
Sierra Mercury/Mariner Power Trim Relays Logo
193 people viewed this question
Top Sierra Boating Experts
nmccully
Jeff Turcotte
Jeff Turcotte
perry richard
perry richard
Are you a Sierra Boating Expert? Answer questions, earn points and help others
