Question about GE (PSS26MSRSS) Side by Side Refrigerator
The two lower drawers in my fridge side keep freezing my vegetables. When this happens the freezer side drips water and then freezes. How do I fix this problem?
    Scholar:
  • 86 Answers
GE's are riddled with sensors. This could be a lot of things. There's a separate fan for them drawers.
It may not be running. The baffle may not be closing. The sensor may be bad and keeps asking for more
cold air. Or the board in the back could be bad. Like I said could be a lot of things. I know you don't want to
read this, but I would get a tech out there. I mostly serviced GE's and they can be tricky when it comes to things
like that. You need a meter to check the sensors. Depending on how old your model is GE may help you
with parts. They're pretty good about items that haven't been out of warranty long...hope this helps.
Posted on Apr 02, 2011
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
Oct 07, 2015 | Samsung RF265AA Bottom Freezer French Door...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Freezer not freezing & fridge warm at top and freezing at bottom.
Check and see if you have a fan that is not working. A condenser fan might just be your problem. The air is not circulating right. If this isn't the solution try turning the frig off for a couple of hours to see if it will correct the problem. BB
Dec 15, 2009 | GE GSS22SGPSS Side by Side Refrigerator
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
204 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
