Question about Cycling
The post on my bike seat is securely in the post hole, but where it attaches to the seat, causes the seat to wiggle left and right.
    Brigadier General:
  • 8,546 Answers
I have a deniese austin manual treadmill and do not know how to open it
Dear Sir:
Thank you by your request, I will help you inmediately.
1) Unpack the carton. Place Main frame and Running track on a flat level floor.
Attach the post left and right onto the Main frame withthe Screw.
2)Attach the STABILIZER Stand with the post lef and right before mentioned 1) onto the main frame annd tightly secured with Screw/Nut.
3) Raise UP the post Left +Right mentioned Before in the section 1)
4) Inser the Handle Bar left +Right in the front Handle bar, then onto the post Left and Right mentioned into the section 1)
5) Put the computer unit onto the fron Handle Bar with Screw.
6) Raise the Main Frame and Running Track up, attach adjustable Rod with Screw Nut and lik Stabilizer stand tightly secure with screw nut.
Warning: On folding up the running track, do make sure que the pin lock knob are porperly enganged and securely tghten to prevent accident.
To unfold, Pin lock simply loose to pull out Knob and gently lower the Running Track.and Ready.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact me
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
Trying to install Sunlite HD tourer rear carrier #45772. on a Rand 18 speed. There are no holes for front brackets in frame. Do you just drill the holes?
Never drill holes in a bike frame unless you have a death wish. "Rand 18-speed" doesn't tell us much. Most cheapo bike frames have a 'brake bridge' with a hole on the center for mounting accessories like fenders. Many racks can mount with a single rather than double front supports.. Lacking that, call a bike shop or web search for "bicycle seatstay rack clamps" to adapt the rack to attach to the seat stays.
Sunlite also makes a seatpost rack mount http://www.bikebagshop.com/sunlite-rack-mount-seat-post-clamp-p-1146.html?gdftrk=gdfV22203_a_7c1316_a_7c5544_a_7c11461678151 which looks like a more elegant way to solve the problem.
Sep 13, 2011 | Cycling
I have a Kulana Sun Fire 26 inch bicycle. Someone stole the seat, including the seat post, what parts do I need to buy to replace the seat?
You'll need the seat and seatpost (duh) and possibly the hardware to secure the post to the frame. Since there are a lot of different seat post sizes out there, your best bet is to take the bike to a bike shop who can size out the frame for the right post and help out with the parts you'll need.
Jun 12, 2011 | Cycling
I have a mens schwinn midmoor bike that I'm trying to find a rear rack for. Where do I attach the rack at under the seat? Do I need a seat clamp attachment? What size? I'd appreciate any help! :) ...
The most secure and sway-free type would be one that bolts to the bike at at least three points, not simply clamping the seatpost.
Blackburn and Topeak make some nice ones. They mostly bolt to those pre-drilled holes above and behind the rear axle and most say what wheel-size bike they will fit plus they have a range of adjustment (usually via bendable metal braces) for reaching that key third point near the top of the seatstays or brake bridge.
Mar 26, 2011 | Schwinn Midmoor Men's Hybrid Bike
Different seat
You do not provide many details so I will try to give you a general answer. It is always possible to put a different seat on your bike. What you need to be aware is that the seatpost (the tube that slides into the frame of the bike), comes in many different sizes, so taking a seat with the post attached from one bike, does not mean it will fit the other bike, however the end of the post where the seat attaches is almost universal.
Mar 17, 2011 | Cycling
I can't work out how to get the seat off my bike? it is a sector i knwo i selected a zing 125 but i had to
Some scooters seat latches operate with the ignition key switch.
Turn it left and right as you lift the seat.
Sometime you have to push down on the seat while you turn the key
Some have a key right on the left side of the bike for the seat latch.
If you have no key, you can pull off the rear rack and then take off the plastics above the tail light.
Once that plastic is off you can reach the latch with a screwdriver or needle nose pliers.
Nov 29, 2010 | Kymco Zing 125 Motorcycles
Where can I buy the part that attaches to the seat post?
Go to your local bike shop with your seat post, they come in all different sizes, so you need to bring it with you.
Sep 08, 2010 | Schwinn Hitchhiker Bicycle Trailer Tandem...
Girlfriend's bike seat and post was stolen and I'm not sure of the seat post size for a replacement. I'd rather not have to bring the bike into a bike store to get measured. Does anyone know the seat...
hi, the seats are a standard size if you go into any bike shop and tell them its a girls mountain bike they will then give you the correct seat, or if you want it measured all you need to do is measure how big the hole is across so look at the hole and measure it across the middle and that will be the size, but if you just ask them for a standard sized mountain bke seat they will then give you the correct one.
let me know if you need further assistance
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 26, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
How do you adjust the seat
Hi there Vriddick
To adjust the seat for height, there is a locking bolt on the seat post, below the seat. Loosen this and the seat should drop down the hole. Lift it up to your specified height and tighten up the bolt. You can also use this method to adjust the direction of the seat in relation to the handlebars, left or right.
If you need the seat adjusted for its angle. Under the seat itself are two bolts clamping two large circular bits of metal, undo these bolts and tilt the seat downwards or upwards, retighten when you have it just right.
Jun 20, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
How and where do you hook on the bike trailer to the bike?
Your bike trailer has a washer looking thing with usually-two holes(one large and one small) The smaller diameter hole mounts to your left side rear axle nut or your quick release wheel nut-meaning, take off the nut or flip thumb tab and unscrew, slip on washer thingy and tighten back down.
The larger diameter hole should be in the downward position like a teardrop, this accepts the bent frame pole from the trailer by use of the spring clip/pin. Slip frame pole into larger hole and lock in with clip and your on your way. ***Just don't forget to attach safety strap from the frame pole to your bike -should the clip ever come undone.(unlikely)
***Do have a bike shop or pro look at the finished hookup if your concerned for safety
Aug 08, 2009 | InSTEP 12-QE111 Quick N EZ Bike Trailer
Cycling Logo
48 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
