Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
The net book does not start at all even with charger pluged in. Even the LED won't light. I replaced the charger but still the same problrm. Thanks, Jamal
    Genius:
  • ASUS Master
  • 1,479 Answers
Unplug the charger, remove the battery, press the power button for at least 1 minute.
plug in the charger, try starting the computer as normal, if nothing happens and it's under guarantee then contact asus (good luck). if not under guarantee, try removing and reinserting the memory. if that doesnt work expect the worst. you might want to take it to your local repair shop.
Posted on Apr 02, 2011
Dell inspiron 1525 pluged in not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Dec 02, 2012 | Dell Inspiron 1525 Notebook
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
I have the oakley bluetooth pro but it won't power up. how can I get this repaired?
I can normally repair them as long as they have no water damage. When the charger is pluged in does the led come on? With a dead battery or one not even installed the led should come on. If it does not then its probably the logic board and Oakley do not sell spares.
Aug 11, 2011 | Oakley O Rokr Pro Sunglasses
My blackberry 7105t won't switch on even battery is ok. i even tried charging it with different charger and connecting it to pc yet nothing happen--blank screen & led light not lit.
Hi there. It sounds like the USB connector has broken off the phones motherboard. You can order a replacement part from www.cnn.cn and replace it yourself. You're looking for the USB charging port. If you're not comfortable taking apart the phone and soldering, your best bet is a new phone. Alex
Jun 30, 2011 | Cell Phones
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
Jun 09, 2011 | Samsung Galaxy Tab Tablet PC
Labtop dosent turn on even with the charger
check to see if ac adapter is outputting dc, poss 18-20 on these
Feb 11, 2010 | HP Compaq nc6000 Notebook
H700 wont do anything
I think the charger is the problem. I ordered one of these and then it wasn't charging the day I got it....it's supposed to go from red, to orange to green as it charges, but the red LED just goes off after a while, before the headset is fully charged. I solved this by charging it through a USB-to-miniUSB cable on my laptop USB port. This worked beautifully....unfortunately I think the H700 chargers are faulty.
Feb 09, 2009 | Motorola Mobility H700 Wireless Headset
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
236 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
