Question about Bosch Nexxt 800 WFMC8401UC
Are there known problems with a small leak with this model
I have a f250 v 10 4x4 no vacuum to lock out or solenoid where does the vacuum come from
Depends on the year. Open the hood, look on "your left" on the back firewall there you should see 2 plastic parts mounted with small vacuum lines and also electrical plugs. This is what operates 4x4 actuation to the axle. Small lines are known to crack and or break and leak. Also the electrical part in the switch is known to fail.
Nov 12, 2014 | Cars & Trucks
I have a 1998 Cadillac DeVille D'elegance and it has a coolant leak the temperature rises but doesn't overheat I just got the car a few days ago and know nothing about it please help
well section off the car on flat ground let idle until leak leaves signs on the ground in front on the wheels hoses, radiator, on right side of car near rear heater hoses waterpump on drivers side hoses engine gaskets.
May 26, 2014 | 1998 Cadillac DeVille
2000 nissan maxima stalls
known problem is the connection at the injectors check for green where the wires are connected to the injectors or check the air filter maybe dirty listen for a vacuum leak this car has lots of known problems
Jan 12, 2013 | 1992 Nissan Maxima
I have OBDII Code P0442 On dodge Stratus SXT 2005
The P0442 means Evapotative Emission Control System Leak Detected (small leak), I think you have known where is the problem.
________________________
more car diagnostic tools you can browse
Aug 16, 2012 | 2005 Dodge Stratus Sedan
Manufactures code p1440 emissions
The P1440 code is for a small EVAP leak. Your gas cap being loose is a common EVAP problem. If not that, the EVAP canister is also well known for developing small cracks.
Jan 28, 2011 | 1999 Nissan Altima
Not washing properly, smells like mold
I have a samsung WF306LAW/XAA and it also smells like mold. I found I had a small leak which turned into a large on over a long periond of time. The leak was in the guide water also known as the silver care kit. The bottom of the washer has foam wire and hose covers to soften the noise, they get wet and mildew. make sure you do't have a small leak and dry out the cavity.
Jul 28, 2010 | Kenmore Washing Machines
Saturn 2002 sl seems a small gas leak on top of gas tank-is it usally the line? cant see where on top of tank.because its still in the car. thanks.
The fuel pumps on this particular model are known to crack. The plastic part of the pump usually cracks across the top which usually results in a leak. Only way to fix is to replace the fuel pump assembly. I have seen this happen several times on this exact model car. Hope this helps. If you need anymore information, let me know.
May 29, 2010 | 2002 Saturn L-Series
Ac leaking how can i find the leak
finding the leak can require special leak detection equip, but based on the known source of most leaks in the model u have the AC compressor front seal is the problem 95% of the time. complete rebuilt compressors are sold on ebay very cheap, old one off and new one on, no core charge
May 20, 2010 | 2001 Pontiac Grand Prix
Bosch Nexxt 800 WFMC8401UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
