Question about Casio Exilim EX-S880 Digital Camera
EX S880 not charging
Same problem
I just bought the EX S880 2 days ago.
>I put the battery in the camera as indicated in the booklet. put the camera on the cradle plug the cradle then I saw the red light flashing. After overnight charge the red light is still flashing and when I take the camera off from the cradle I can''t turn it on. I return to the store bought the same and Igot the same problem
>Any help?
  • idsherman Sep 03, 2008
    Same problem. EX S880 is put in cradle and light turns red. Within a minute or so, the red light blinks and does not seem to charge. I cannot turn the camera on to take photos, but can view photos while camera is in the cradle. Any ideas would be appreciated.
  • Anonymous Sep 12, 2008
    can not power on
May it's a bad battery but when you buy something ew you wxpect thing to be perfect and not to spoend 5 extra dollars for a battery
Posted on Oct 02, 2008
  • 477 Answers
You have a bad battery common when the battery sits to long with out being charged they are like 5 bucks on ebay.
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
The red light that indicates its charging keeps flashing
How old is the battery? Keep in mind they aren't meant to last for more than a year or two, regardless of how often they're used. Generic replacements are actually inexpensive these days. Here's some from Amazon:
Jun 06, 2009 | Casio Exilim EX-S880 Digital Camera
Battery Problem Casio EX-S880 Digital Camera
Ive had this happen twice. The first time I went back to the store and talked to the tech people to see if it was a problem with the camera itself but ended up buying a new battery. About a week ago, I finally found my charger to plug in the camera that I hadnt used in weeks to find the same problem once again. It must stem from long periods of non use. After finding this question I continued my research and the Casio website tells you to call 1-800-435-7732. Dont know if that helps much but I will be calling them in a little while. Good luck.
Mar 08, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 will not turn on
The problem is the spring terminals inside the camera are not making good contact with the battery. I had to use a screw driver and gently push them to the left to make better contact with the battery terminals. There are three connections. I stress that you be gentle. This not the long term fix but you will be able to take pictures in the short term.
Feb 25, 2009 | Casio Exilim EX-S880 Digital Camera
Won't Charge.
I just had this problem with my camera. all you need to do is get a new battery. But when you aren't using your camera take out the battery. If you don't, you will have this problem again.
Jan 29, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 I put my camera on the charging dock and the orange light comes on. After about 15 seconds it starts flashing. I can't turn my camera on at all. The only way I do is to view them on...
if you try pushing the battery in further it might turn on, if that doesn't work just get a new battery, but make sure to take it out when you aren't using it or this will happen again.
My casip ex-s880 camera will not charge
very common issue its a bad battery you can get one off ebay for like 5 bucks
Aug 16, 2008 | Casio Exilim EX-S880 Digital Camera
CasioEX-S880 will not charge.
Hey ITDude,
You do need to charge the camera by putting it in the camera dock and the ac cord should be plugged into the camera dock. It is possible that the battery has gone bad so you could try getting a new battery. If neither of these options work I would have the camera looked at by an authorized service technician. I hope this helps!
Go Ahead. Use Us.
Jun 18, 2008 | Cameras
Not sure whether the battery is charging or not
If you cannot find a solution to your problem you may want to email He has good advice and good used parts at a fair price.
May 22, 2008 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
123 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
