Question about Garden
The wire roller doesnt seem to be workin is there anyway to test the motor to see if it works ?
    Scholar:
  • 133 Answers
I have repaired many chain saws and never ran into a wire roller. If you get a good answer, please post it. I am always looking for knowledge. Thank you!
Roger
Posted on Apr 02, 2011
I disconnected my back wheel from the controller and now the motor doesnt work
You disconnected while under power didnt you? if so the controller output transistor(s) have failed. most likely the cause why it doesn't work anyway.
Jul 21, 2016 | Electric Bicycle Motor, Bike,electric...
Washer fluid motor/pump not working
You need wiring diagrams when you work on your own vehicles
Dec 18, 2012 | Cars & Trucks
Power is on, motor doesnt run
1)Lube the deck belt with 100% silicones or wax follow the instr. manual
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor,for worn and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty..
God bless you
Dec 05, 2012 | Proform 860 Competitor Treadmill
Belt doesnt run
see the video how to lube the deck belt.
2) LUBE the rollers bearing too
4) Test the input voltage motor, if there are the motor need repair see my personal TIPS for troubleshooting help
see the block diagram
God bless you
Nov 30, 2012 | Weslo Cadence G 5.9 Treadmill
The drum doesnt seem to turn and makes a VERY LOUD grinding noise. It does seem to be heating up though.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
And it sounds like you have noisy drum rollers.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Aug 11, 2010 | GE Dryers
I hav a microphone problem.Its working properly on my pc,but when when i connect it to my social netwoking site it doesnt work properly,some wired noice comes out th speaker of th one who is listning to my...
Go on mic. configuration and select on microphone use from configuration mic. name and test the mic. On test mic not works mic,is posible to need a driver for mic and need download and install the driver.
Jul 30, 2010 | Computers & Internet
I have an hobart welder-handler 150, when the welder is set to the lowest setting 1 the wire will not feed through, the motor is running but not feeding. When the setting is on 2 or higher it works fine
why would you need to go to the lowest setting?. anyway look at the feed rollers, make sure they are the correct size for the wire, secondly check the clutch mechanism on the wire mounting centre post this might be too tight, thirdly check the linner this could be crimped.
If the set works ok on number 2 it should be ok on 1, perform the set up again, ensure the rollers are not tightend down on the wire.
lets now if the problem clears,
Ken
Oct 05, 2009 | Hobart Welding Tools
Electric window drivers side not working
If the switch on the passenger side works, it should not be the relay. These switches are usually the fault, and can be dissasembled carefully and contacts cleaned. Theyre not that expensive anyway if I remember last time.
Other things to consider are the wires coming into the drivers door. make sure that one of them is live, and if you ascertain which on is the live, which the ground/earth, and what is the window motor one, you should be able to test the wiring.
Jun 01, 2009 | 2006 Peugeot 505
Blower motor isnt workin still
did you test the motor from an outside 12 volt sorce? or did you plug it in the car wireing? after you got it in and found it did not work, have you test light the power wire for motor in car to see if its got good light or if its weak light. There is a chance you got a bad motor. or its not getting full power from car wireing. I believe thies heating systems work thru the ac systems. i'am gussing is a climent control heating.
Feb 03, 2009 | 1992 Cadillac DeVille
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
