Question about Logitech V10 Computer Speakers
The sound page on my control panel does not show this speaker.
  • 961 Answers
The Logitech V10 speakers are USB attached so, click on "start", then "control panel", Find and right click on"device manager", open and click on continue. Click on the box with + next to Human Interface Devices. Your speakers should show up here. Do you see a warning ?, !, or yellow triangel? If so click on taht and follow proceedure. Right click on your device and you should see "disale". If you see "enable" click on that and exit. If your spaekers require an update, I recommend getting it from Logitech. If you have questions, let me know at "add a comment"
Dave
Posted on Apr 02, 2011
My levono C460 system sound is off so no sound what can i do?
Hi
3 possible solutions:-
• Adjust the Windows volume control - select the speaker icon from the Settings Charm or click the arrow on taskbar to show the hidden icons in Windows desktop mode, then click the speaker icon. Ensure that the volume is turned up and the sound is not muted. Adjust the volume, bass, or treble controls to eliminate distortion.
• Reinstall the audio driver.
• Disconnect any headphones from the headphone connector - sound from the speakers is automatically disabled when headphones are connected to the computer's side-panel headphone connector.
I also give a link below to a page from which you can download the full manual for future reference.
Desktops and all in ones Lenovo Series all in ones Lenovo C460 All in One...
Cheers
Oct 26, 2014 | Computers & Internet
Can not locate sound for my speakers
Hi Marvette,
Not sure what your problem(s) is. Your speakers will be activated if they are plugged into the speaker port. The sounds are used by all software on your system.
Is the speaker in the lower right corner turned off? A red X will be on. Click the speaker and click the speaker and it will go off.
Go to the Control Panel \ All Control Panel Items \ Sound icon.
There are three [4] tabs, Playback / Recording / Sounds, fourth does not matter for sounds.
That will show all sounds that widows uses.
HTH's. Describe the problem more if not.
Wayne
Nov 02, 2013 | Computers & Internet
SAMSUNG N150-i have check sound/audio devices in the control panel and made sure volume is set right..selection...problems with volume...icon showing 100% but still no sound,help please!
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 18, 2013 | Samsung N150 (36725723009) Netbook
The sound does not work
I can definitely help you on your question. Let's troubleshoot. First, please click the speaker icon on the System Tray. Check if the mute has a check. Or if you don't see any speaker icon. Please go to the Control Panel. Go to start and click Control Panel, then search for Sounds. A new window will show up, you can see in that window the speaker icon. Please click the icon and a new window will appear again. Now go to Level Tab, please check if the small speaker icon has a no sign and the level of the volume is on the right side. If there is a no sign just click it to remove it, if there's none. Please go back to the Control Panel, and go to Systems. Once you are on the Systems, click the Device Manager link that is on the left top side of the page. Now you can see all the hardware of your computer. If you see a yellow exclamation point under the category of Sound,Video and Game Controllers, there is a problem but you don't need to panic. All you have to do is right click on the item that has a yellow exclamation point and select Update Driver Software. Then a new window will show up, click the first option and that is Search automatically for updated driver software. Now, it should work. If the sound still doesn't work, you need to buy a new sound card for your computer.
I hope I helped you in your question.
Thank you!!
Aug 09, 2011 | Microsoft Windows Vista Home Premium...
I have Windows XP and my Dell speakers are not working. I have checked the control panel and it shows all the volume is correct. I cannot get any sound out of them.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disk you might need to download the sound drivers
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
hope this helps
Jun 11, 2011 | Dell A215 Computer Speakers
What if in the bottom right corner of my screen there isn't a speaker, does that mean i have to install my headphones?
Go to your control panel window and open you Sounds and Audio Devices. There should be a box to check there that will show up the speaker icon down by your clock.
Best of luck..
Nov 18, 2010 | Dell Dimension 2400 PC Desktop
I do not get sound from my speaker, the control panel shows it to be sending a digital signal. How do I change it to analog so the speakers will work.
Try changing the default sound device from high definition audio output to speakers. You can find it under sound in control panel.
Oct 12, 2010 | Acer Audio Players & Recorders
No sound, checked control panel, all shows the
No sound, checked control panel, it shows all sound at the max.
Feb 25, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
My speakers dont work
check for an online solution. like go to the bands wedsite
Jun 30, 2009 | Logitech R-10 Computer Speakers
No sound
1. Are your speakers turned on and plugged into the correct jack on your sound card?
2. Is your sound card recognized by your OS?
    In Windows, press the Windows Key+Pause/Break to bring up the System Properties page.
    CLICK on the Hardware tab, then Device Manager.
Is there a yellow exclamation point under the "Sound, video and game controllers" subheading? If so, you will need to either install/reinstall the sound card's driver or resolve a device conflict. Walk through the options on the device's Properties page.
3. If your speakers are on and your sound card is working properly (as reported by Device Manager), it could simply be that your sound is muted. Open the Control panel (Start>Control Panel)
Open the "Sounds and Multimedia" icon.
Verify the "Show volume control on the taskbar" checkbox is checked. If this option is not available or is grayed out, see below.
If you were able to check this box, click ok and close out of this window and the Control Panel.
Double-click the sound icon in the systray and verify that all the sound volumes are mid-way or higher.
4. If Windows thinks your Sound card is working properly, your speakers are on and turned up and Windows' software volume control is turned up, go back to Device Manager and Highlight your Sound Card. Press the Delete key on your keyboard and confirm that you do indeed want to remove this device.
Reboot. If your Sound card is functional, Windows will redetect it and offer to install the drivers for it. You may need your original Windows CD to complete this step.
Jul 17, 2008 | Acer Computers & Internet
Logitech V10 Computer Speakers Logo
140 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
