Question about JBL PRX515 Speaker
How do i tell if my problem if the high freq diaphram or the cross over
  • 635 Answers
The crossovers in professional speakers don't fail that easily. It could be a blown tweeter. To confirm remove the metal grille-- remove the screws of the Horn Tweeter -- remove the cable connectors on the tweeter terminals ( Red and Black wire ). Now if you have a multimeter put it in Ohms range and touch the probes on the tweeter terminals-- It should show a reading betwwen 4 to 8 Ohms depending what is written on the back of the tweeter magnet. If you do not have a Multimeter you can take an ordinary cell/battery ( 1.5v ) from a TV remote and touch the terminals of the Horn Tweeter with the battery. + to the tweeter + ( a small red dot or mark will be there on the tweeter ) and -- to the tweeter -- . When you touch the terminals or give 1.5 volt supply the tweeter will make a scratching noise.
If you do not hear the scratching noise - it indicates a blown tweeter coil and will need replacement.See link below for spares:-
http://legacysoundservice.com/catalog1/product_info.php?products_id=1417
But if it does, you are in trouble and will need professional help from a electronic technician.
Could be blown HF Amplifier, suspect the crossover last. They seldom fail.
Revert back for more help
Posted on Apr 02, 2011
    Problem Solver:
  • 9 Answers
The only way to do it is to remove the tweeters from both speakers and exchange (reverse) them between the speakers. If the problem remains in the same speaker enclosure, the problem is the crossover. If the problem moves over to the other enclosure the tweeter is the problem and needs to be replaced. If you are not confident that you have the tools and skills to easily remove and reinstall the tweeters, do not attempt this but bring the speakers to a specialty audio dealer that has a service department. It will cost money but probably less than replacing speakers you destroyed in an effort to repair them.
I have accusound floor speakers and a Yamaha receiver how do I connect, because I only had the bottom half of the speakers working?
The receiver has separate output for subwoofer , centre and satellite which are for Low Freq , Mid Freq and High Freq respectively - you cannot connect all range speakers or Stereo speakers
Jun 13, 2015 | Yamaha Audio Players & Recorders
Codes p0300 p0304 1997 chrysler sebring
sounds loke timing off and or crossed wire or bad wiring check connections to plugs may have a bad wire or connection
May 24, 2013 | Cars & Trucks
I have a husqvarna 141 chainsaw and it dies as soon as it starts. It is full of fuel and had fuel filter replaced.
If you have changed the filter the next port of call is to service the carb, remove the top cove and air filter, remove the two 10mm nuts holding the filter back plate and remove the plate, now remove the two 7mm bolts holding the carb, remove the two cross head screws holding the ignition switch, and carb plate, lift out the throttle push rod, and diss connect the fuel hose, the carb should now come away, uner the cover with the single cross head screw ( pump side ) will be the pump diaphram, under here will be the main inlet screen, make sure this is clear, under the cover with the four screws is the metering diaphram, and under here is the inlet needle, replace both diaphrams if the appear aged or are distorted or hardened.
Apr 04, 2011 | Husqvarna Garden
Model 141 husqvarna saw would cut off as soon as i hit the throdle now it will not start
For some reason its running too lean on the mixture, this may be due to a fuel blockage, or it just wants richening up on the mixture screws, start by replacing the fuel filter in the tank, check the fuel hose up to the carb for signs of leaking/cracks or splits, if the carb has standard screws to adjust the mixture, turn each one ( H and L ) out 1/2 turn ( anti clockwise ) on each, if it still does not run any better it may need a carb service. To remove the carb, first remove the two screws securung the air filter, then remove the two 10mm nuts securing the air filter back plate, remove the wire throttle rod, now remove the two cross head screws from the carb back plate into the crankcase, finaly remove the the two 7mm studs securing the carb, remove the fuel hose from the carb elbow ( use a suitable plug to stop fuel sqirting out of the hose a set of forseps works well ) with the carb off remove the single cross head screw in the alloy pump cover, here you will find a gasket and a pump diaphram in that order, there will also be a main fuel screen which will need cleaning or replacment, if the pump diaphram looks aged replace this importent component, now turn the carb over and remove the four screws securing the metering cover, here you will find the metering diaphram and a gasket in that order, replace the diaphram if it looks aged or the metal disc is bent, the metering lever controling the inlet needle should move easily and be set level with the sides of the carb body, if too low just bend it up, if too high bend it down, this is about as much as you can do with the carb without special tools. Whilst the carb is of check the induction rubber, to do this remove the two m4 allen screws holding the carb back plate on, pull the back plate up and out,behind here you will find the induction tube, make sure it has not split, below this tube is the impulse seal check this is seated correctly and not split.
Let us know how you are getting on.
Jan 30, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
To connect speaker wires to unit there are blue wires and black wires. where do I attach them to the unit
hi,
connecting right speaker.
1.connet the speaker cord with the plug to the speaker high freq right (R) terminal
2. connect the speaker cord with white strip to the speaker low freq right (L) + terminal and its black cord to the -- terminal
do the same for connecting the left speaker to the speaker high freq left (L) and speaker low freq left (L) terminals
ok
Jan 05, 2011 | Aiwa Z-L700 Shelf System
No sound in horn when plugged in bi amp connection
The question is whether or not you get any sound from the horn when in full-range. If so, then either the input jack for the horn is defective, or you are not passing the signal. A quick check would be to send the full-range signal (at low volume) to the high-freq input. You should hear the horn work. If not then the connector is defective on the crossover board.
If you get no sound from the horn in any configuration, then the coil is blown for the horn. This can be replaced. It is usually a 22a or 22ti diaphram
Let us know what you find.
Dan
Dec 09, 2010 | Peavey SP2 PA Passive Speaker
Worcester 24i combi when in shower hot water flicks on and off can hear gas igniting and extinguishing
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Aug 06, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Samsung 42' Rear projection - High freq squeal
solder around pins on flyback transformer,see if this will solve your problem.some flybacks will make this sound, like a ringing noise.
Jan 19, 2008 | Samsung HC-P4241W 42" Rear Projection...
JBL PRX515 Speaker Logo
1,348 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
