Question about Drive Medical Phoenix 3 Wheel Compact Scooter
Just bought this from an individual who knew nothing about it. Scooter is in excellent condition however it has been sitting for a bit. The problem is the scooter only goes forward when in the High speed mode, and that "high" speed is very slow. I checked all connections and the battery took a good chg. could you maybe help me with an idea of what's wrong with it? It is a Drive Phonenix 3 scooter. Thank you! Jade
Jade
This model Drive Phoenix 3 wheel is found for sale at pharmacies and is subject to floor model abuse.
Most common abuse is not recharging batterys and letting them sulfate thus
reducing life of of charge.
I have found that the foward and back-up levers have been bent
by people sitting and squeezing both levers at the same time. the resulting misshaping of the levers results in a very slow speed comand to the controller because of limitted movment of speed control. The result is that main control (turtle/hare) must be advanced to fast (hare) position to get scooter to move.
I have had success straightening levers by carefully bending them in opposite direction on my Phoenix 3W ( which was a clearence item with no warranty.)
The real (legal)solution is ordering a new lever having a technician
replace it so as not to void warranty.
Hope this helps....jth1939
Posted on Feb 09, 2012
4 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
  • 7 Answers
SOURCE: After a period of use the Scooter turns itself off.
sounds like it might be a bad throttle pod, or the brake is overheating. If you can pull the rear shroud off and drive it for a while you can check to see if the brake is overheating. Be careful when checking it because if it is really hot it will burn your fingers. The throttle pod can be checked with an ohm meter but i'm not sure off the top of my head what reading you should get. let me know if you would go that far and i'll get it for you.
Posted on Mar 10, 2009
gewiz
  • 1271 Answers
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
Posted on Jun 14, 2009
I've got an Jonway scooter, now I bought it for next to nothing as it is for work and back. But it spatters when it reches 70kmh. I've checked and replaced filters etc. Where and what am I missing
you got it for next to nothing because the fault was known to the owner
most scooter engines run out of "puff" at around that speed if the crank shaft seals are not in good condition and I am guessing that the owner knew that and was not prepared to pay the repair costs
check the plug as well and if it shows signs of the enter electrode burning away , that is running too lean from the seal problem
Mar 20, 2016 | Jonway Motorcycles
Batteries ran completely down now fully charged scooter wont work.
hi if youre batteries have been sitting for 18 months without a charge they r probably no good now after batteries sit for a long time the plates develop a coating & when u do charge them the they will not charge properly..youre charger guage is not a true reading the only way Is to use a battery LOAD tester this will give u a true reading on the condition of youre batteries...u can buy a battery load tester of e/bay for aprox $35 ........
Sep 06, 2015 | Golden Technologies Companion II Travel...
Memory is used up by excel
I don't think you can. It's a real resource hog especially if youre using 2010/13. See below.
Excel 2003 is officially limited to 1 Gigabyte (GB) of memory.
This limit appears to be a limit on the working set memory used by the Excel process, which is the memory reported by Windows Task Manager.
Although Excel 2003 has a substantially increased memory capacity, many of the individual specific memory limits listed below have not changed in Excel 2003.
Excel 2007 is limited to 2 Gigabytes of memory for the Excel process under Windows XP/Vista (Windows memory limit).
This 2 Gigabyte limit is a limit on the Virtual Memory address space. Virtual memory used by a process is larger than the working set memory reported by Windows Task Manager, so the amount of useable memory under Excel 2007 is considerably less than twice that of Excel 2003.
Because Excel 2007 (Excel12) also requires more memory to store the indexes to the increased number of rows and columns you may not be able to load larger workbooks under Excel 2007 than was possible under Excel 2003. Memory Fragmentation may also mean that it is difficult to make use of all of the available 2 GB of virtual memory.
Many of the individual memory limits listed below have been removed in Excel 2007.
Excel 2010 is available in 2 versions: 32-bit (2 Gigabytes of virtual memory) and 64-bit (8-Terabytes (which is 8000 Gigabytes of virtual memory)).
The 32-bit version has the same memory limits as Excel 2007, but the 64-bit version, when used with a 64-bit Windows operating system, will have extremely large memory limits.
Note that the different versions of Windows Vista 64-bit and Windows 7 64-bit support differing amounts of RAM.
Aug 17, 2014 | Microsoft Excel for PC
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Need Charging Cord Only (Not the Battery)
I would check company web ste for information on the unit for a part number. Then check Ebay or any parts supplier that pops up on web. Good luck, Chas
Aug 12, 2012 | Pride Rally 3 Wheel Scooter
Problem with color alignment on DocuColor 1632
Below is a link to the user manual, the aligment procedure should be in there. Xerox DocuColor 1632 User Manual
Jun 16, 2017 | Xerox DocuColor 1632 Laser Printer
Hi I have a Korg concert 3500 piano. I need a manual, so I can find out about its midi connections. Does anyone know where to download it? appearenly its not on Korg's home page. a good dag to you...
I bought a Korg Concert 3500 from an Estate sale this past weekend. Stored for 10-15 years in excellent condition, you would kick me hard if you knew what I paid for it. It has the original manual in excellent condition as well. I would be happy to attempt to scan you a copy if you still need it. Otherwise send you any info via e-mail. Let me know. Happy to help, Love my vintage keyboards!!! jjsandell at msn dot com.
Oct 01, 2010 | Audio Players & Recorders
My electric scooter dont go when i pull the trigger
The batteries need to be charged. Even if the batteries are drain, the scooter will all ways be able to push it's own weight for a little bit. But, when you try to ride it the current draw goes up which the batteries are unable to supply because they dead. So, charge the batteries and you should be fine.
Jun 24, 2009 | Razor E100 Electric Scooter
My brother's Vespa scooter fell over and won't start up again.
If it falls over and wont start it just gets flooded.
Simply remove the spark plug (inspection panel is behind your feet) and leave it sit for a half hour or so. Use the kickstart every now and then (with the scooter turned off). The excess fuel will eveporate and when the sparkplug is replaced it will start up but it will be smokey for a few minutes. Just leave it sit idling for a while to clear out.
Feb 28, 2009 | Peg Perego Vespa Scooter
Drive Medical Phoenix 3 Wheel Compact Scooter Logo
266 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
