Question about Denon Audio Players & Recorders
Hi I have problem on PM737 amp only one chanel working right is very faint
  • sblagay Apr 03, 2011
    Hi thanks for you input man .yes I did try to do this and the fuses were not ok I have changed them and transistors as well,still fuctions only on one chanell .Chanell balance is in the midd.ok checked all that etc .how ever one speaker was not ok when this happened so I looked and sow that wire/wound restor.was falty so I changed that at least what I could .the speaker works ok when I plug it in on the chanel that works same the other one but still only on righth chanel A speaker and B when pushed in not joy let me know what you think then thanks Stephen
    Hi thanks for the input cheers for that yes I am the amp tech but not HIfi expert this is somthing new to me but I think its all the same ,I have solved half of the problem now we'll see next one I have other problem with my Pioner it has bad earth .all the mono jacks when touched are like live and not the hot one whcih is the midd. of the plug so when I put one mono say from tape chan which I dont use to earth its quiet and nice not a his so still need to solve this one on the other chanel cheers again and thanks Stephen
  • Denon Master
  • 6,993 Answers
First, be sure your speaker is good. Test both speakers one after the other on the channel that is working to actually confirm if it is not a speaker fault....
After that, cross check your speaker wires and make sure they are intact.
Now check your input wires make sure they are good. Also, check the speaker balance settings on the amp and make sure it is at the center.
Check your CD player connected to the amp, make sure it is set to Stereo and not Mono. Mono will make on one speaker work.
If non of the above seem to be the cause of the problem, then the problem has to be from the Output of the amp. Check the output fuse on the channel that is not working. If the fuse is intact, then it means you will have to change the output.
I hope the above makes sense to you. Let me know if you still need more assistance....
Good luck.
Posted on Apr 02, 2011
  • Walesarumi
    Walesarumi Apr 03, 2011
    Hello, are you conversant with electronic repairs? At this point the channel needs to be read with ohms meter in order to detect precisely which component is bad. This a better than doing trial and error. The meter reveal where the fault is coming from. I hope you understand this.
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
Unit shut down (suspect due to surge protection) after playing it on speaker A/B relatively load. Some smell to the unit at that time. After good 3 hr to cool down, the unit still does not start...
Stick a fork in it if it acts that way with no speakers attached.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 28, 2011 | Denon DRA-395 Receiver
Shashij_2001@yahoo.com
TURN THE BALANCE CONTROL IN THE MIDLE
Jul 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
Amp wont work
Hi I have a Yamaha DSP 3090 Amp my right main Chanel is not working Amp goes off when i try to put the power on i think it goes on protction mode?after trying for 5to10 times it comes on, test mode all chanels work well not sure whats wrong ? can anyone slove my problem
Jan 02, 2010 | Audio Players & Recorders
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Left channel volume is very faint as compared to the right channe
It sounds like the preamp section is working but the power amp is not. Look at the power supply section and see if it is getting power to the power amp and if ok check the power transistors or IC.
Feb 13, 2009 | Yamaha Audio Players & Recorders
Harman-kardon citation 7.1
Go to diyAudio.com and try asking there....
Jan 10, 2009 | Harman Kardon Audio Players & Recorders
1 channel only works???? plz help
Inside the amp check copper6 for loose connection
Oct 28, 2006 | Volfenhag ZX-7180 Car Audio Amplifier
340 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
