Question about Western Digital WD WD1600AAJB 20PK CAVIAR SE 160GB PATA HD 7200RPM 8MB 3.5LP Parallel ATA Hard Drive
I want to replace an old HDD (Quantum 52 Mb) from an old computer which is still useful for somethings. I bought an WD1600aajb. I declared into the CMOS setup like an HDD of 504 M (1024 cil, 16 heads, 63 sectors). I boot from the disk A in DOS 6.20, I run fdisk, I make the partitions and restart in order to format the partitions. But surprize, the partitions are not maden, I have the message Invalid drive specification. I tryed many times, no positive result. Without a bootdisk in drive A the message is DRIVE NOT READY. Any Ideea? Thanks, Regards, Marius
bluegreenash
  • 661 Answers
SOURCE: Trying to format a 500GB HDD at full capacity
sounds like the SATA - PATA converter doesn't accomodate for a 48 bit LBA (to handle disks of more than 137 GB)
you need to get the correct converter, as this one is not compatible, you should be able to return the converter as not fit for purpose (needs LBA 48bit).
Posted on Oct 11, 2007
Crankstart
  • 696 Answers
SOURCE: WD My Book 320GD external HDD - recognized by computer, but cannot read, says it has to be reformatted
Sorry to say not that many of the Free ones are either A) Actually free(most just show you the files then request money. or B) Al that good. GetMyDataBack seem reasonably good but any attempts you make to recover or fix the drive run the risk of further damaging files.
Both of your stated problems sound like file structure problems although the later problem sounds like the issue may have been the result of impending hardware failure.
First, IF you cannot afford to loose your data, DO NOT try the following suggestions and send the drive immediately to a data recovery specialist(I recommend Armor-IT in North America, if you're elsewhere give me Region and City and I'll point you to an appropriate location).
Now, IF you can live without you files in the event this causes new damage and are simply looking for a cheap/free shot at salvaging the data, open your start menu and click RUN(XP)/SEARCHBAR(Vista). Type CHKDSK X: /F and hit enter(change X to the current drive letter of the external drive).
Then reboot your computer, a screen will come up about disk checking or consistency check, allow it to run it's course.
If this fails, try GetMyDataBack, it's free and can resolve some minor issues. If these suggestions do not work you will likely need the help of a pro. Respond with your Region and City and I will point you to an appropriate Pro.
Chris
Posted on May 29, 2009
  • 2678 Answers
SOURCE: PURCHASED A NEW HARD DRIVE MDL: WD1600AAJB-00J3A0
The bIOS should automatically pick up the HDD, Formatting is done via your OS, Configuring only applies to PATA drives nnot SATA ones and partitiong is done with a third party sofware such as partition magic.
Jumper settings for PATA drives are printed on the HDD label.
Posted on Mar 22, 2010
jestamac188
  • 79 Answers
SOURCE: WD My Book-Delayed Write Failed-Can't access-Files deleting!
Hi when you buy a hard disk you do not get instructions on how to change from FATS to NTFS. Your hard drive is set to FATS by default,which limits you tranferring files up to 4GB.If you changing to NTFS does 2 things. 1.you can transfer bigger files.
2. You will lose all data on the drive so you have to save any files to another drive ect
To change to NTFS, go to Start then Right-click on My Computer and select Manage. Under Storage click on Disk Management. Now find your hard drive in the list and Right-click on it and select Format. Under File System change the Answer to NTFS and leave the Allocation Unit to default.Click on Perform Quick Format if you want. click OK and confirm your OK with losing all data on the drive,and your done.
Regards Bill
Posted on Apr 18, 2010
bronk50
  • 27725 Answers
SOURCE: dear sir I have WDC
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Posted on Dec 31, 2010
Why is my quantum fireball hdd's led light flashing, bios failed to detect hdd?
Wow, you have a Quantum Fireball? I haven't heard about that hard drive model family in years, decades actually. They were last marketed back in 2001 but were most popular in the early to mid 1990s. Given the very low Mean Time Before Failure (MTBF) values of drives in that era, I am surprised that the drive has survived up to this time.
If I were to make a guess, I would say that your old IDE Fireball has gone the way of the dodo bird. Time to get something new and much more modern. IDE drives are no longer manufactured as it is an outmoded technology in favor of SATA. If you still have a machine that uses IDE, then definitely replace the machine with something much more modern and faster that will have a more spacious SATA drive.
Sep 01, 2014 | Computers & Internet
Quantum fireballlct15 20
If the hdd is ticking/clicking it needs replaced, If it is corrupt get your hands on a hdd caddy and repair it using another pc/laptop, if you need further assistance just ask, hope this helps,
Sep 19, 2011 | Quantum Fireball Lct15 (QML20000LC-A) 20...
I have a fairly old HDD and would like to recover some information from it. What I am trying is to use a IDE to USB cable to connect my Quantum Fireball lct20 3.5" HDD to my note book through USB port....
Hi, I dont think you need drivers for this, if connections are all ok, and its powered up and spinning up, it should show up as an external hard drive on your computer as, C: D: E:, or whatever.
Do not just unplug it to remove it, click on "removing external drives" first.
Hope this helps.
Dec 31, 2017 | Quantum Fireball Lct15 (QML20000LC-A) 20...
I need a Driver/Firmware for a Quantum Fireball 3.5 series part Number CX13A011 HARD DRIVE
as I stated in my first thread , no firmware or drivers
needed for internal HDD , and remember Windows
uses an allocated partition of 8 gigabytes for the OS
which will only leave 5 gigabytes left on a 13 gigabyte
HDD , and for solid state HDD , the only difference is
solid state has no moving parts , there are trying to impress us with technology that is over 35 yrs old
like a calculator other than its buttons its solid state
Feb 05, 2010 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
I need the id info for a quantum lps52, cly--hd--pre--lz--sec--size
P R O D R I V E L P S 5 2 A T QUANTUM NO MORE PRODUCED Native| Translation ------+-----+-----+----- Form 3.5"/SLIMLINE Cylinders 1219| 751| | Capacity form/unform 52/ MB Heads 2| 8| | Seek time / track 17.0/ 5.0 ms Sector/track | 17| | Controller IDE / AT Precompensation Cache/Buffer 64 KB LOOK-AHEAD Landing Zone Data transfer rate 1.750 MB/S int Bytes/Sector 512 4.000 MB/S ext Recording method RLL 2/7 operating | non-operating -------------+-------------- Supply voltage 5/12 V Temperature *C 4 50 | -40 65 Power: sleep W Humidity % 8 85 | 5 95 standby W Altitude km -0.060 3.000| -0.060 12.000 idle 5.5 W Shock g 6 | 60 seek W Rotation RPM 3662 read/write 6.5 W Acoustic dBA 45 spin-up W ECC Bit 48,WITH 11BIT BURST COR MTBF h 60000 Warranty Month 12 Lift/Lock/Park YES Certificates CSA,FCC,IEC380,SDA,TUV,UL4...
Oct 05, 2009 | Maxtor Computers & Internet
I have a computer with an intel al440lx motherboard, pentium 2 processor w/mmx, ATI rage 3d graphics card ,creative sound blaster pci sound card, 7GB quantum HDD and 40GB seagate HDD and 1.024 GB SDRAM...
This is not a software problem. The problem lies in the motherboard.
The motherboard which you are using is an AL440LX motherboard which supports a maximum of 384MB of RAM. The computer will not recognize any more RAM. In order to use 384MB, you will have to add a 128MB RAM along with the 256MB already present and not any more !!
This is the solution !!
Jul 30, 2009 | Computers & Internet
No start-up...
first install your graphic card drivers for sure and second check the jumpers settings on mobo after you let me know again please... and dont forget to use a non usb/wireless keyboard to get in the bios with, sometimes that does it ...?
Oct 21, 2008 | MSI K8N NEO2-Platinum (MS7025) Motherboard
New hard drive
Hi ,
Appreciate the direct "Ask me" again.
I have had very good experience with most brands of hard drives.
  • for durability - Seagate Barracuda;
  • for performance/speed - Western Digital;
  • for high transfer rate - SATA rather than IDE.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 06, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum fireball 10.2gb
The computer speed completely depends on the speed of quantity of RAM, HDD, processor and FSB of mother board. Your processor is good enough to give better result with windows XP and did not mention about the availability RAM, if less than 256 MB, you need to upgrade and you can upgrade HDD not so mandatory if you have more than 20% free space. Under maintenance practice do regular "DEFRAGMENTATION and CHECK DISK" from selecting driver properties under tool tab.RAM will surely give boost and do degramenation
Apr 16, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Western Digital WD WD1600AAJB 20PK CAVIAR SE 160GB PATA HD 7200RPM 8MB 3.5LP Parallel ATA Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
