Question about IBM ThinkPad R40 2681
Left my laptop in storage 4 3 yrs when i fired it up it wont get past check time and date then it asks for a code. heck i cant remember and its upsetting trying to let kids use it
  • snowrideralw Apr 02, 2011
    Is it a BOIS password code that may have been set for security reasons?
  • 124 Answers
The CMOS battery that keeps the date and time needs to be replaced.
The battery is fairly inexpensive however, finding one, depending where you live may be the biggest hurdle.
Replacing the battery is also simple IF you feel comfortable disassembling the laptop.
Posted on Apr 02, 2011
Testimonial: "i recieved an answer pretty quickly. info was straightfoward and to the point. will see if this helps will post and let others know."
I cant get into my account gmail, it keeps asking for a code and then when i dont no onger have that numbe ri cant remember what the last spercific day way i used the month and yr yes not the date i need...
Could you please try writing this being careful to spell the words properly. Write it in your word processor and use spell-check. Then when it's organized copy it through the clipboard into Fixya.com. I don't understand your question as it's written. Gmail doesn't ask for a code. It asks for your Gmail address which is also your Chrome address and then it asks for a password.
" it keeps asking for a code and then when i dont no onger have that numbe ri cant remember what the last spercific day way i used the month and yr yes not the date makes no sense at all.
Mar 26, 2015 | Google Gmail
HOW TO SET AN ROTER FOR AN 92 CADILIAC DEVILLE
standing passenger side vechicle with crankshaft pulley facing your.number one sparkplug location should be at twelve Oclock position.you need to know cylinders locations front cylinders left to right is 1 3 5 7 and back cylinders left to right is 2 4 6 8 and firing order is 1 8 4 3 6 5 7 2 your ignition timing need to be 10 degrees BTDC AT 800 RPM. YOU SET TIMING YOU NEED TO DISABLE SPARK ADVANCE BY CONNECTING JUMP WIRE OR PAPER CLIP STRECTCH AND BEND YOU NEED TO CONNECT JUMPER WIRE TO A AND B DLC TERMINALS. if ignition timing way off you wont get no spark.but check ignition fuse and make sure distributor cap and rotor good shape also spark plugs and wires.if all is good your ignition module or ignition coil bad.the 4.9 can be time if you have 4.6 engine cant adjust ignition timing PCM control timing.code scan vechicle first before buying new parts.look for ignition module or pcm fault codes.look for faulty crankshaft sensor or camshaft sensor.many things will cause no spark conditions.
Dec 22, 2012 | Cars & Trucks
Front loader hotpoint wf840 running 'test' cant remember how to reboot. last time i had to do this i had to hold down one of the buttons for a few seconds and wait till a specific word came up on...
Here are the instructions to (just) clear the 'test' depending on the date code:-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to norma
l
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Have Casio Exilim EX-Z750, 4 yrs. old. Every time
read the manual again. and reset to automatic update
Apr 07, 2010 | Casio Exilim EX-Z750 Digital Camera
After 2 yrs unused have decided to run in new dell
Did you plug in the scan unit and then installed the software?
If you did you will have to unplug or turn off your scanner then uninstall your software.
Reboot and the with the scanner turned off reinstall the software. If the install asks you to plug in your scanner, turn it on. If it asks you to reboot, then reboot. After rebooting, turn on the scanner then start the Easy Scan Utility. This should work.
It worked for me.
Jan 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Maya44 card virtualdj 6.0 cant get time code to wook can you help
maya44 card virtualdj 6.0 What is this ???
How can anybody understand what you are asking. ???
If you are having a time stamp problem, simply check your time and date at the bottom right of your screen. If the time or date is incorrect, you will recv. this type or error message.
If it is not correct, right click on the time and left on adjust or change.
Hope this helps you, please verify the above.
Oct 29, 2009 | HP Pavilion dv6000z Notebook
IBM ThinkPad R40 2681 Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
