My tv wont come on at all. Is there a reset buttonm on the digital lifestyle tv
  • Steve Allison
    Steve Allison Apr 02, 2011
    You always need to include any model numbers of units for which you need help. However, your problem is common and likely means the main power supply has failed.
  • 6,993 Answers
There is no reset button to solve this problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Best regard...
Posted on Apr 02, 2011
Tip
Bose LifeStyle 38 Manual Download
Download Bose LifeStyle 38 System Manual
Have you misplaced your Bose LifeStyle 38 Owners Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Users Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Bose LifeStyle 38 Video Mode
Reset Bose LifeStyle 38 VChip Password
on May 02, 2010 | Televison & Video
Tip
Bose LifeStyle 48 Manual Download
Download Bose LifeStyle 48 System Owners Manual
Have you misplaced your Bose LifeStyle 48 System Users Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Owners Manual?
I hope that helps.
Bose LifeStyle 48 Video Mode
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Bose Lifestyle 48 System
I need to know the manufacturer of the digital lifestyles tv
the manufactures name is corian usa 800-278-6334 i had this problem and it turned out that u have to use LG codes.i also had to use lg codes to code direct tv sat box
Mar 03, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
U-Verse remote for Digital Lifestyle
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
Aug 13, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
When is the TV code?
Digital Lifestyles says that their products are "too new" for the market and you should use a LEARNING remote. Great customer service, huh?
Apr 27, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Reomte code
gital lifestyles tv will work with LG codes 11423 for Direct Tv with this you can control volume, to control power put remote in tv mode
Dec 23, 2007 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
