Question about Freezers
My icemaker is filling up too high and as a result the ice is all joined together - can you help?
    Scholar:
  • 86 Answers
Chances are good that it's not the ice maker, but the water valve. If the valve is stuck open just a little water will drip in and constantly freeze. If the fill tube in the back of the cabinet is froze to then that's your problem...cheap part and fix...hope this helps...ps shut off your ice maker. You don't want it to burn up.
Posted on Apr 02, 2011
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Have viking side by side referagator , freezer model # ddrb304. I installed copper line to ice maker yesterday It is not making ice. Checked that water supply is on. Appreciate any suggestions Lou
make sure you have strong water pressure to the frig.
Do the ice maker have a shutoff arm? or a shutoff switch? either way make sure it is on. by now there should be water in the icemaker tray. if not then manually pour 1/2 cup of water into the icemaker. if it does make ice then replace the water fill valve.
if there is ice still in the ice maker tray you still have to check the water fill valve before we can say the icemaker doesn't work.
need a meter to check the continunity of the water vavle. if the valve is open repalce valve, if there is continunity the the valve is good.
hope this is helpful. if you cant do this ask a friend who is an electrician to help you
Mar 27, 2010 | Freezers
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
Sub zero 550 icemaker not making ice/not working
first off, make sure its under 17F in freezer as icemaker will not start above this...you need to make sure the icemaker is coming on..if so, you may just have a bad water valve. I'd put four ounces of water into the mold and see if it starts by itself dumping out your ice. if it dumps out your ice..look to see if the inlet tube that brings water into your i/m is not frozen up with ice in it..if it is, defrost with hair dryer and wait and see if it starts to work ok dumping ice.if it starts to work ok..replace fill valve..
If you find everything looking normal and your sure no ice plug in fill tube..you can try to start i/m manually..if your confident enough to work with tools and electricity...find the T and H they are close to each other on front of i/m. take an insulated wire and make a jumper that each end has 1/2 of end stripped of to go into i/m T and H..keep in there for 30 seconds and i/m should start on its own..remove jumper and either put i/m back or be ready to catch water should it come on. if no letters on front of i/m just gears. find the small 5/16 gear and turn until rake arm starts to come up. this i/m should start on its own ... if it starts and runs fills, replace i/m...if it starts , but does not fill..your inlet valve may be bad. it helps to have a volt meter for this.. you can remove top and find valve up there or its under the bottom front vent plate. locate wires that go onto valve. use your volt meter to check for 111-130 volts when you restart your i/m as already talked about. remember, it will take several minutes before you notice anything..the i/m needs to cycle first and get to the spot it fills..if you get power and no water and your sure there is water..the inlet valve is bad...
Jul 26, 2009 | Freezers
I have a whirlpool refg. with built-in ice maker model# ED25DQXDW02. Everytime the frig. goes to fill the tray it fills it then over flows some. Is this a problem I can fix myself.
probably have to replace the icemaker take it out and look at the mold and see if you have some teflon coating that has come of and or some water deposit buildup under im on heater on bottom of icemaker. this causes it to let the water drip down on the back of im an causes iceblock in the dispenser bucker. you can order an icemaker 1- 877-262-1479
May 27, 2009 | Freezers
ROPER RT18AKXJW01 Ice Maker Malfunction
Hi, If the icemaker is leaking next to the head, all you can do is changethe icemaker. See if it is leaking between the head and the tray. You can order the icemaker off my web site www.whirlpoolpartssurplus.com. If I can assisrt you further, please let me know.
THanks
Vic
May 17, 2009 | Freezers
ICE WITHOUT PLUMBING
it really doesnt matter how full you fill the bucket. round cubes will probably dispense just fine if you have access to that shape ice.
One additional thing, be sure to turn the icemaker off to prevent the fill valve from going bad and to keep it from making a loud buzz about every 10 minutes. thx peyton
Jan 25, 2009 | Freezers
Freezers Logo
49 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
