Question about Refrigerators
We have a GE Profile refrigerator/freezer Model GSC23KSTA SS. The control panel will not light up. We tried to unplug the unit for a couple minutes but had no response. Now it is also making an annoying clicking noise that goes away only when the tab that you would push to dispense water/ice in pushed in
    Scholar:
  • 86 Answers
Three things. There's another board on the back of that fridge. Could be the display board or there's a wire harness down at the bottom of the freezer door. Pull the bottom grill off and check to see if there is any corrosion on that connector. GE's are notorious for that. If that checks clear then without looking at it I would say with 98% sure, it's the board in the back...about 189 dollars. Call GE (customer relations) chances are good that they will replace that part, but you would be responsible for any labor. It's a quick fix (20 minutes if that) so labor should not be that bad...hope this helps.
Posted on Apr 02, 2011
Testimonial: "Thanks appliancguy. This was super helpful. "
GE profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. Pulled back panel cleaned the condenser fins with compressed air andchecked the connections. runs fine but can'
I had this happen with my fridge when the door was open for awhile when I was cleaning the inside. I did what you did, clean everything behind it. Pay particular attention to the circuit boards, there may be reset buttons in that area. Then unplug the freezer for 10 minutes (make sure it's for a FULL 10 minutes) then plug it back in and try it.
Feb 03, 2015 | GE Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
GE bottom freezer PF22missaww i came home from vacation and it was at 60 degrees , unplugged it for 10 minutes and plugged it back in , ran fine for a month , came home from work and the unit is warm again...
GE Profile bottom freezer erratic.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which may have reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Jun 13, 2017 | Refrigerators
Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Mar 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
366 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
