Ok this is going to sound weird. I have asked every maintance/ heating person I know and got nothing. I clean a house for this single women. she has baseboard heating. I've been cleaning there about a year now. Back in December she asked me to wipe down a wall above this baseboard. first her walls are painted with flat paint which didn't help but anyways..it was like wiping up sut. There is no forced air anywhere in this house, she does smoke but that would be yellow. she has only lived in this house about two years and she had i freashly painted before moving in. house is about 15 yrs old. no propain, no karosine, nothing like that, it is worse directly above baseboards but its every where. there is a film on her furniture, floor, and i even found it on the toilet on the side closest to the baseboard. Any idea at all what this could be?? it is wrecking her funiture and drapes and i'm concerned about her breating this in. i sprayed it with striaght bleach thinking maybe black mold and it stayed black and when you and anything but water to it it smears like smoke sut. she does burn candles
  • 43,501 Answers
Both smoking and cvandle does produce a bit or soot... after many days and weeks it doe accumulate....where??? on the walls and on the top of smooth surfaces...
The walls will get more over the baseboard radiation as a result of the extra air flow through the radiators...they work by convection and heat the air as it moves through.. in the bottom and out the top...then the **** in the air sticks to the walls...
Also many times candles will burn very dirty and make tons of soot, but we all know what smoking does and the fact that the second hand smoke can be worse then the actual smoking...
My opinion would be that the soot is a result of the two together...
But it is not likely that you will get her to give up either the smoking or the candles....:-)
heatman101
Posted on Apr 02, 2011
    President:
  • 3,074 Answers
It maybe grease, i would suggest using kilz on all the walls and repaint with a semi gloss.
Got a weird starting problem with my Citroen berlingo van
Sound like it's starter motor at fault. With you saying it's after a long run there will be a lot of heat in the engine/gearbox this could be causing the starter to stick, like you say after half hour or more it's OK and short journeys you have no problem.
May 04, 2017 | Citroen Cars & Trucks
Report a person who I know is using the site to extort money from women
go the the local police station and ask to talk to a squad member.that handles this problem Make sure you take your facts and all details so that they can proceed to take action.
Jan 16, 2015 | Computers & Internet
Mitubishi wd-73738 turns off after 1 min
Weird noise is high pitched or even grinding sound? Sounds like a fan but is not?
Dec 14, 2012 | Mitsubishi WD-57833 57" HDTV
Do i need to vent my 3510 dryer
Maybe not. What did the manufacturer say about venting? Are you prepared for a house full of dust? What about all the extra moisture you will trap inside?
In the past, in the winter time, to conserve heat, I have vented my dryer to the inside through tripple thick nylon womens hose. I didn't save enough $ to offset the dust I got in my basement.
Another consideration: What does your local housing authority (building inspecctor) say?
If you ask me, I'd say vent.
Let me know what happens - Thanks
A
Sep 14, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Just filledd up an old dakota hot tub model126-dkn-4248-2 and ita been running for about 4 hous and wont heat up i would also like an owners manual for one but dont know were to look
it may take longer to heat to desire temp. if nothing chang have you adjust the temp higher . if everything check ok check high limit switch next to the control box ussualy red bottom push soft in
Sep 13, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Limited heat and timer not advancing
something in the vent or blower housing the reason it heats for a short time then has to cool is a possible restriction problem
Aug 19, 2009 | Whirlpool LGB6000KQ Gas Dryer
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
Samsung D500 mobile is continually 'Beeping' - HELP
batteries are easy got for these phones! ebay etc. button on back of phone near top, press it in and battery comes off, regards the beeping...try resetting the phone to factory settings.....menu/settings/ok/scroll down to "reset settings/ok "sound settings" if that doesnt work ok "all" you may loose your personal settings by doing this! let me know how you get on,
Mar 26, 2009 | Samsung SGH-D500 Cellular Phone
Maytag performa dryer PYE2300AZW
my dryer was working perfectly fine, but I think i had way too much laundry this day. anyhow, it just stopped working. the weird thing is the timer still runs I turn it to 90 and then it stops at 0. WEIRD!! i had my dad and husband take it apart, but of course we are reading the blueprints and tring to find matching numbers but no can do. we give up. HELP
sign the Dryer Monster
Oct 16, 2008 | Maytag HYE3658AY Electric Dryer
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
