Question about Garmin Nuvi 265W GPS Receiver
I blew the fuse in my garmin nuvi 255w car charger. where can i get a new fuse
  • 17,970 Answers
Look for online or just about any large automotive store or The Shack (RadioShack) just make sure to take your blown fuse in and verify they are the same size.
It is a 3AH 250V fuse; additional details could find in this LINK.
Hope helps (remember to rate and comment this).
Posted on Apr 02, 2011
How do I update my GPS? it never came with anything besides the charger. Garmin NUvi 255W 1TV869173 Thanks, Mary
First, you will need a USB cord. You can buy one from Garmin for 15 dollars at: https://buy.garmin.com/shop/shop.do?pID=1345&ra=true
To install the new maps, you'll want to run WebUpdater. You can find the link for webupdater here: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Feb 28, 2011 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
I've had two Garmin Nuvi 255 and have had problems with the car charger after a short period with both. I cannot charge my garmin while in a vehicle. Is this a common problem?.
you probably have a blown fuse in the charger plug..... Unscrew the silver tip end of plug CAREFULLY its spring loaded check fuse and replace with 3A fuse
Nov 22, 2010 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is...
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Nuvi 255w-Where can I get a replacement fuse for the car powercharger? What is the fuse number?
On the plug charger unscrew the silver or black bottom tip of plug.. you can probably get a fuse from radio Shack or any Electrical supply store.
Oct 22, 2010 | Garmin Nuvi 660 GPS Receiver
Other than using the car, how can I charge my garmin nuvi 255W
You can charge it by connecting it to your computer with a usb cable. This takes about 8 hours to charge. Or you can buy a mains charger which takes around 4 hours to charge.
Sep 06, 2010 | Garmin nuvi 255W GPS Receiver
My new garmin 255w is not charging
I had the same problem. The plug wasn't sitting right in the charger hole.
Jun 25, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 265W GPS Receiver Logo
405 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
