Question about Jandy LXI 300 PROPANE POOL HEATER -
Heater burner will ignite but will cycle off after aprox 30 seconds . will not stay ignited
    Top Expert:
  • Jandy Master
  • 5,075 Answers
Dirty or bad flame sensor clean or replace
Posted on Jan 30, 2016
3 Suggested Answers
  • 246 Answers
SOURCE: Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Posted on Oct 16, 2009
  • 368 Answers
SOURCE: We have a Jandy Lite @ Model LG125N pool heater.
The reason it doesn't light is that the electrically operated gas valve is not coming on. It could be defective or the control circuit that tells it to come on is not doing that. If you have a meter and can connect the leads to the wires on the valve you should get 120VAC when the control circuit tells it to open. If you don't get this then the control circuit is not telling it to open. With the power off, check the resistance across the thermal safety device. It is located usually on the far left. It has two wires and they connect to a small axial leaded device. If it gets too hot it opens and prevents the heater from coming on. If the resistance value is very low, under 1 ohm, then it is OK. Other switches that could be open include the thermostat switch, the water flow switch, etc. Any one of these would prevent it from coming on. If you call the Jandy technical support number they might be able to help you diagnose the problem. I hope this helps.
Posted on Aug 14, 2011
Raypak RP2100 Model P0127NCO spa heater with a problem.
Cycling on/off like that can be a number of things. One of the more common problems is a "flow" problem. Try cleaning out your filter. If it is this type of problem, the flow switch is not sensing proper amount of water flow.
Jan 15, 2013 | Raypak Pool & Spa
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
I have a problem where the heater ignites easily, stays lit for 30 seconds, then turns off, then kicks back up in 30 seconds. Burners look great? Not sure what could be wrong?
If you have a pilot their will be a flame sensor that's part of it. If this is a glow plug start it will be a probe that goes through the fire wall and is just above the burners. When you get flame the electrons align so that you will get a signal back at the ignition control that will let teg heater run. If it dosn't get a signal it shuts down so you don't get a build up of gas. Then it reset's and tries again. What your describing is a bad sensor or wire. Could be carbon build up on the sensor. If you can't find any problems with these you may have a bad ignition control box. First I would check the wire, connectors and probe itself.
Oct 09, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
Have a Goodman GMT070-3B which the vent motor seems to be sticking. I took apart and cleaned the brushes and reassembled. The furnace will come on only after what seems like the vent motor comes up to...
The whole assembly must be replaced.
The sequence of operation is -
Combustion fan purges the heat exchanger. A pressure switch verifies combustion air fan is running. Usually a 30-45 second purge before the hot surface ignitor glows, or the spark ignition starts.
Gas valve opens after 10-15 seconds and main burners light. Control board monitors for flame and shuts gas valve after 2-3 seconds if main burner does not light.
If burner does not light, some boards repeat this for 3 tries, then locks out and is reset by cycling power.
Air blower comes on after another 30-45 seconds after main burner ignition.
Times may vary based on the specific controller board. A flow chart and timing sequence should be located somewhere on the unit, usually in the fan compartment.
Dec 16, 2009 | Goodman GMS90703BXA Heater
Have a rheem criterion II. Model
The way it lights is that the gas is spread from one burner to the next by either a flame tray or small holes drilled in the burner tubes. If the flame does not get all the way across the burner tubes within a few seconds, the unit goes out on failure. Clean and inspect each burner tube, not just the orifice. Clean any tray that connects the burners. You can use a small wire brush or tooth brush but be careful near the glow igniter as it is very fragile.
Dec 12, 2009 | Heating & Cooling
Blower Motor cycles on & off
whats happening is thje heat exchanger is cooling off and cycling the fan off this is a normal occurance whenever the unit is first turned on.
Dec 22, 2008 | Heating & Cooling
Furnace tries to ignite
thi is either a sensor or the control module
Dec 07, 2008 | Goodman Heating & Cooling
Explosive Ignition
Check the alignment of the igniter to burner. It should be in the flame of the burner but to one side or just below. Does the igniter glow about 15 seconds prior to the gas valve opening or just a second or two. The igniter should glow 10-15 seconds prior. If the temperatures outside are unseasonably cold, you could be experiencing a gas regulator condition. If so, as the temperature rises, the condition would lessen. Call your gas company to get the regulator tested and gas pressure checked.
Jan 03, 2008 | Goodman GMS90703BXA Heater
Jandy LXI 300 PROPANE POOL HEATER - Logo
42 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
