Question about BenQ FP222W LCD Monitor
What does IC mean?how is it a problem to LCD?
  • 2,098 Answers
Sharp 42 inch LCD will not turn on but the red power light lights up sometime
Have you tried presssing down on a button on it while trying to turn it on? or pressing 0 on its remote control? if it will not turn on at all, generally would mean its an IC fault, internal IC short circuit so will not turn on at all. this fault is usually on the display board main board behind the screen if its of the inverter type cold cathode screen, if an electronic ic device shorts out anywhere along the power side of the circuit the lcd will not turn on. but to give an exact answer it would have to be properly tested.
Oct 26, 2011 | Sharp Televison & Video
Hello, My Westinghouse ltv32w1 LCD TV is only 2 years old. Sound is fine, picture is not so good: Initially when TV goes on picture is okay, then after 30 minutes, the image breaks up into verticlal...
verticle lines are most likely a bad tube or convergence problem. You will not be able to fix this your self . I suspect a bad convergence ic
Sep 17, 2008 | Televison & Video
Olivia brand TV wont' keep channels remembered
This means that the memory is not working as it seems that the memory back up is not effective. it can be fault on the processor IC as the voltages , the data IN/OUT signals must be checked.
If voltage to back up is absent then there will be memory loss. If not the IC must be replaced, use proper soldering/desoldering irons with static protection when replacing.
Sep 21, 2011 | LG 37" LCD-TV 37LC25R 37 in. LCD TV
5130 lcd.blank
LCD blank means there may be your:
1.display ic damaged
2.display may have broken
So visit the nearest nokia care center and change your display and update it at once.
Thanks for visiting fixya.
Aug 19, 2011 | Nokia 5130 Cellular Phone
White screen 6500 slide I need help plz I've
Display can be Lcd,Flex connector,board connector,display IC etc.
If you already try at least 2-3 lcd, take another step of replacing flex connector 2-3 also, to make sure that the item you bought has no defect.
If this 2 parts didn't make it, check the board display terminal if its clean and corrosion free. resoldering each terminal may be helpful enough.
last option is replacing the display IC, it will serves as a fuse of it, a clystal square type that generate current to be able to display on screen.
Jun 28, 2011 | Nokia Lands Phones
My cell phone(nokia n70) is not diplay any operation. but the monitor is in order .what can ido?
Only 2 reason for blank lcd on N70,first lcd socket and the screen it self and 2nd Display IC (It need help from service center). to make sure Open your phone cashing and also all the screws.than release a LCD socket from VCB clean socket on VCB up with a thinner or alcohol. becarefull when cleaning lcd socket use a tooth brush and not much alcohol because it can make a flex on lcd.Congratulation if it work but if still blank it mean display IC need to change.
Jul 12, 2010 | Nokia N70 Cellular Phone
No display
That is one reason for no display. Onother could be a broken connection to the LCD. Third could be the display IC goine. If it is the last one then donate the phone to Nokia who have a special box at Nokia Care Saying "Your old phone is fantastic. Donate it." Gone IC means that even Nokia will scrap it. Beyond economic repairs. While if it the earlier two reasons, then a visit to Nokia care is warranted.
Aug 21, 2009 | Nokia 6600
Display stopped showing anything
As it the result of a fall, it is the LCD bone or the display IC gone. LCD is replaceable but a gone IC means that the phone has to be scrapped because it is not economic to repair it.
Aug 16, 2009 | Nokia E61i Cellular Phone
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
BenQ FP222W LCD Monitor Logo
54 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
