Question about Keurig B60 Coffee Maker
Keurig stopped working. water seems to no longer be heating up? it says ready to brew automatically & then the water slowly drips out. any thoughts?
SOURCE: Keurig B50 Ultra brewer
This is a known problem with the B50 which Keurig will acknowledge if you press them hard. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models, which may explain why it isn't on the market anymore.
Posted on Jan 23, 2008
EsWorld
  • 1618 Answers
SOURCE: Water goes directly to drip tray instead of to the brewing head.
Thr coffee grind is too fine, adjust or try tamping lighter.
Posted on Aug 06, 2009
  • 464 Answers
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Posted on Nov 08, 2009
  • 7 Answers
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Posted on Mar 29, 2010
espressonist
  • 1711 Answers
SOURCE: I have had my Keurig B60 for about a year and a
We have
here below a video link which is specifically for your case. The video is so
clear that we thing that any other words are useless.
http://www.youtube.com/watch?v=DqRs4Ott21s&playnext=1&list=PL88559E01E8136AA5&index=35
This one
will help if the above have not work out
http://www.youtube.com/watch?v=nIBvzWWI-LY&feature=related
If it does
solve your problem try also to do de-scale often
http://www.youtube.com/watch?v=l8diybgU6E0&feature=related
Posted on Dec 30, 2010
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
After de-scaling my girlfriend's keurig mini, the 'add water' indicator does not function properly. It always thinks there is water in the heating tank even when I know it is empty. Because of this, the...
You could be correct in your assessment and if so, as long as the device is under warranty it needs to go back for servicing. If you open the chambers, the warranty is Void and the device a boat anchor.
Jan 21, 2014 | Keurig K10 K-cup Mini Plus Coffeemaker...
My Coffee maker is not brewing, and the screen says de-scale. I don't know what to do, I remove the water container, turned it off and back on. I will appreciate your help, thanks Andrea
Step 1: Plug Brewer in and turn power "ON".
Step 2: Pour approximately 64 oz of the vinegar into the Brewer until 4 beeps signal the tank is full.
Step 3: Wait about 6 - 8 minutes for the vinegar to heat up and the green "READY" light to go on.
Step 4: Place a ceramic mug in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP...just press the Brew button.
Step 5: Repeat the brew process 4 or 5 times pouring the contents of the mug back into the Brewer after each cycle.
Step 6: Now let the Brewer stand for 4 hours while still on.
Step 7: Place a ceramic mug on the Drip Tray and run 4 brew cycles, pouring the contents of the mug into the sink after each cycle.
Step 8: Turn the brewer off, let the remaining vinegar cool, and drain the brewer as instructed above.
CAUTION: Vinegar may still be hot. Remember to replace the Drain Cap.
c. RINSE
Step 1: Fill the brewer with hot tap water.
Step 2: Power up brewer.
Step 3: Wait about 6-8 minutes for the water to heat up and the Green "Ready" Light to go on.
Step 4: Place a ceramic mug on the Drip Tray and run a brew cycle.
Step 5: Repeat brew process 4 times for a total of 5 cycles.
Step 6: Drain the brewer as instructed above.
CAUTION: Water may be hot. Remember to replace the Drain Cap.
Step 7: You may need to rinse again to eliminate any residual taste.
http://www.keurig.com/Customer-Service/Brewer-Registration-And-Support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions_04_30_2004.ashx
Jun 06, 2011 | Keurig Platinum B70 Coffee Maker
The water no longer shoots out. Now it slowly drips and does not brew the cup of coffee. Any ideas?
run white vinegar or CLR thru it, see if it is just clogged up, if not then the heating coils are bad, just toss it
Oct 29, 2010 | Keurig B70 Coffee Maker
My keurig seems to be heating the water all day???? normal brennantom@hotmail.com
Keurigs are ment to have water at the ready... otherwise... you might as well get a Mr. Coffee...
any Mr. Coffee will brew a cup of coffee... use a heaping teaspoon and add 12 oz or water...
May 02, 2010 | Keurig B100 Coffee Maker
My Keurig B66 will no longer pump water up to brew, I have had this less than 6 mos, what should I do?
it seems that it does not pump water in, after switching it to ON, it stays running for a few minutes then shuts OFF without even showing "READY TO BREW"..
Jan 02, 2010 | Keurig B100 Coffee Maker
My Keurig pot will not stay on, nor will it get "ready to brew"
Mine just started doing the exact same thing today. I just bought it a little over thirty days ago. I called Keurig {1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week}
They are sending me a whole new unit (3-10 biz days) and told me to discard my old one. Said it was a problem with the internal water heater so it powers down automatically after it fails.
It typically makes a boiling water sound after brewing as it heats the next batch of water... that is where it is failing in mine.. and yours as it seems. You can call and see if yours is still under warranty and possibly get a replacement unit. Serial number is on the face of the unity behind the drip tray on the front. It's long .. three sets of numbers and letters.
hope this helps
Dec 19, 2009 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
79 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
