Question about Garden
We just had a new hot tub installed. The GFCI breaker contnues to trip no matter what out electrician does. The wiring is all new and up to code. Any ideas? Thanks so much!!!
    President:
  • 3,074 Answers
You will need to recheck all the wiring in the house and inside the hot tub, as something is crossed,nicked or shorted. Without being there it is hard to help. You may want to check the GFCI itself as it may be bad, Good Luck Tim
Posted on Apr 02, 2011
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
My hot tub trips the GFCI. THe GFCI holds when I disconnect the wires running into the hot tub. I have disconnected EVERYTHING from the circuit board including the heater and the GFCI still trips.
Sounds like wet or bad wiring somewhere but u should do a visual inspection of all the wires & connections first then through process of elimination. Turn off breaker disconnect all wires and connect one wire then turn breaker on & if it dosent pop the. Turn it off and connect one more wire and turn the breaker on & continue until you get the breaker to pop and the last wire or board u just connected is your problem & go from there.
Feb 14, 2016 | Pool & Spa
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 18, 2013 | Pool & Spa
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
Jets will not come on after filling and pushing on switch
There are several things to check.
the first and most likely is that you have a Ground Fault Circuit Interrupter (GFCI) that is tripped.
It is required by code to have any whirlpool tub, spa, or similar equipment GFCI protected. on a whirlpool tub, a good electrician will place the GFCI device within sight of the tub, in the bathroom. it looks like the same GFCI receptacles you have on the countertop, but without holes to plug things in. a lesser electrician will place a GFCI receptacle inside the service access underneath the tub. (this can be a hatch in the side of the tub, or a cabinet door in on a wall adjoining the room) a bad electrician has been known to place it in a completely different room, or under the floor, with the power cord of the tub passed through the a hole in the floor to plug in. find this, and press the reset button. if it solves your problem, great. if not, go to step 2 (also, occasionally, the GFCI device is a GFCI breaker inside the breaker panel - check to make sure the breaker is turned on and not tripped, as well)
If you reset the GFCI and it immediately trips again, there may be a problem with the pump motor. find the access hatch (if you haven't already) and unplug the tub. try the reset again. if it holds now, it is the pump. if not, it is either a failed GFCI (have it replaced) or a ground wire in contact with a neutral wire. (fixed by moving the ground)
if the GFCI resets, or will not reset (newer GFCIs have an interlock feature that prevents them from resetting if they don't like the flavor of the incoming power) and there is still no power to the pump (use a plug tester, or plug a lamp, or radio in to test and make sure there is power to the spa tub), and you have confirmed that the breaker is on, there may be a switch that is off, (the same electrician who put the GFCI device in a walk-in closet across the hall, also had a switch that turned the whole thing off) or there may be a wiring problem somewhere. at this point, it might be worth your while to bring in an electrician to trace down the problem. - you would have to check each point in the circuit to find where there is a wire disconnected or broken.
If there is no problem with the electricity to the tub, then you have either a switch problem or a motor problem. the motor problem is unlikely, as it usually results in electrical symptoms, as well. the switch is an air switch. the button on the tub is an air plunger, that pumps air into a tube, and pushes another plunger in the switch that turns the pump on and off. the plunger can stop pushing air (unlikely, but possible) the tube can come loose, or the switch can stop working. the first two are easily user-repairable. the last may take an authorized service professional, depending on the design of the pump.
If you have acces to the pump and switch please let me know I will walk you through what to look at there to fix if the plug is good.
good luck with this - hopefully it is just a GFCI.
Mar 13, 2011 | Whirlpool Home
Dream Maker spa GFCI plug was all corroded. I cut off the standard plug that was corroded and installed an industrial grade 120VAC plug with the proper polarity. Plugged the spa back into the GFCI outlet....
Did you make sure you observed the correct polaity on the cord? The white wire should go to the silver screw on the cord cap. The black wire should go to the gold terminal (brass) and the Green wire should go to the Green screw. If the plug was corroded, is it possible that the GFCI is also corroded? They aren't that expensive and you could replace the GFCI yourself if you're sure you can locate the circuit breaker and turn it off.
Nov 22, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
My hot tub still trips the breaker,and i replaced it with a new gfci. What other things can i ck.
If your hot tub is pulling more amps than amps sent your breaker box, you'll keep tripping the breaker. Check the rating on the hot tub and compare that to the breaker rating. You may need to uograde the wireing. Make sure the wire gauge is up to code.
Mar 21, 2010 | Balboa Instruments Duplex Digital Panel 2...
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
