Question about Lenmar (LBZ323S) for Sony VAIO VGN-CR220E/R, VGN-CR305E/RC, VGN-NR430E...
Inserted cd to install a lenmar lbz323s battery. clicked on sonybiospatch and nothing happens. just get a popup window with a bunch of ?'s
What is pop-up windows?
pop up windows are nothing but html and javascript codes inserted into source code of webpage which will shoot these windows up when you activate those codes.
For example,popup windows are normally used to pop up ads when we access certain sites. This way they earn more money when you click on those popup windows.
Oct 16, 2010 | Facebook Social Network
I am installing the HP psc 1210 all-in-one printer right now to my a different computer then I originally had it on. I hoooked the printer all up and inserted the installation CD but nothing pops up for...
try plugging your printer in and turning it on the computer should detect the device and ask for the driver disc to be inserted. or you can open the install files from my computer and click on setup/install
Aug 03, 2010 | HP PSC 1210 All-In-One InkJet Printer
Install new CD for printing projects.
goto Start/programs/Accessories then to Windows explorer or my computer then goto ur CD drive then click on setup.exe
Mar 23, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Can you change windows 98 into xp
yes, you will need to buy the upgrade either online to download or by CD but a word of advice if the computer is for personal use windows vista would be better and if its for business Xp its better
Jan 31, 2010 | Microsoft Windows 98 for PC
Wmp 11 on vista
right click on your cd rom drive. Click on properties, then, autoplay>Select Music cd from dropdown menu. then select "take no action" for disabling WMP popup , if you have another cd player software, choose it to make that popup when you insert cd.
Sorry to say, That wonf fix your WMP but the problem. And sorry, there is not enough info to help you on WMP fixing.
Thanks
and yes, please dont forget to Rate, if it works.
Apr 10, 2009 | Microsoft Windows Media Player
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
My disk drive isn't working. When I put a disk in and close it, nothing happens.
Firstly lets see if your drive is working!
#put in a disk you know works and has files of some sort on it
#If nothing is still happening , goto my computer and right click on your CD drive and click "explore"
Do you now see files ?
#if not right click on "My computer" and click manage
#the "COmputer Management" Console will now popup and you will see a selection of headings on the left , click the plus sign on "Storage" to expand it then lcick on "Disk management (Local)
#in here you will see all the storage devices attched to your computer , including your Hard Drives , Floppy Drives , USB Flash Drives etc.. , from here you should see your CD Drive , if you do and right click it and explore the drive and you do see files , change the drive letter of your CD-ROM drive from the default D: to say like F: or something , right click the CD-Drive in the Disk management and click change driver letter , and follow the instructions.
#If you dont see the files or you dont see the CD-Drive at all do the following:
1. right click my computer
2. click on properties
a new window will popup
3. click on the hardware tab
4. click on device manager
the device manager console will now open , from within here find your CD/DVD Drive under the DVD/CDROM drive heading, right click the appropriate drive and click on uninstall
now reinstall with the drivers and restart.
also if this doesn't fix your problem try upgrading the firmware of your Drive.
**im assuming your running Windows XP for that solution but i would think the process in Vista would be very similar.
If you have a spare computer that is unused maybe you could try it on that machine and see if it works , if it does a fresh installation of Windows on your current machine may be the solution as it could be infected with a virus which just may have corrupted the window drivers.
Feel Free to ask more if this doesnt fix it:
Thanks!
Apr 02, 2008 | Computers & Internet
I cannot install my Web camera on my window 98 PC with the CDprovided with PC Camera CS630.
Wow, you have the CD? Please upload the drivers from the CD. Please use a different computer than the one you are having difficulty with because the CD drive may be causing the problem.
Dec 20, 2007 | Intel CS630 Webcam
Lenmar (LBZ323S) for Sony VAIO VGN-CR220E/R, VGN-CR305E/RC, VGN-NR430E... Logo
71 people viewed this question
Top Lenmar Computers & Internet Experts
David Payne
David Payne
Are you a Lenmar Computer and Internet Expert? Answer questions, earn points and help others
