Question about Dryers
Whirlpool Gas Dryer idler pulley assembly (# 691366)
The pulley fell off, but everything is intact, and I need no new parts. When I re-install it (that is, place the pulley back in the slot which looks suspect) there's no tension. Apparently, if only I had taken a peek at it before it fell off, I could've fixed it in 2 seconds. What am I doing wrong?
  • 1 more comment
  • the1alroy Aug 05, 2008
    right-o I thot the pulley was the last thing the belt went around but it was the motor. I would've also helped if you'd sed 'think outside the box'. thx.
  • russorick Dec 18, 2008
    Need help installing idler pulley assembly also.Does someone have instructions on how to install?
    rickpake@msn.com
  • mickeyNo7 Apr 21, 2009
    I have a Kenmore 70 Series dryer & the belt broke. When I looked inside, the idler pulley (691366) was laying on the bottom of the dryer not attached to anything. I can't figure out how/where to attach it to the dryer frame, or how the belt interfaces with it.
  • 770 Answers
Pull the belt thru the ider not around it if you cant get it..post your email i will send you the guide on it along with your model number
Posted on Aug 05, 2008
How to remove front idler
Dryer Idler Pulley (part #691366)-How To Replace - YouTube
? 6:06
https://www.youtube.com/watch?v=YoJ7k30kXhE
Nov 14, 2011 - Uploaded by AppliancePartsPros
Buy the new Dryer Idler Pulley 691366 ... We did not have toremove the rear panel with this design, it was ...
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ...
? 2:53
https://www.youtube.com/watch?v=RZ09dH4-7Ho
Jul 6, 2010 - Uploaded by RepairClinic.com
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ElectricDryer Repair .... If the belt is around the drum ...
Dryer Idler Pulley Replacement - GE Dryer Repair (part ...
? 3:37
https://www.youtube.com/watch?v=bm8s2vVuxvk
Sep 17, 2012 - Uploaded by RepairClinic.com
The most common reasons for replacing the idler pulley... ... GEdryer tune up, belt, drum bearing and front ...
Dec 25, 2015 | Dryers
The nylon or plastic belt restrainer on cabrio wed6600 dyer melted and lodged on drive belt mechanism. What is left of part appears to be a plastic or nylon closed ring drive belt retainer. How would I...
Lift the idler pulley assembly up toward the dryer drum to detach the metal tab on the assembly from the dryer base, and slide the assembly out of the open slot in the bottom of the dryer cabinet by pulling it toward you. Take the idler pulley assembly out of the dryer cabinet and dispose of the part.Slide the bottom bar of the new idler pulley assembly into the open slot in the bottom of the dryer cabinet and push down to set the tab into the hole in the dryer base to lock the assembly into place. Move the idler arm forward and place the dryer belt around the idler pulley by hand.here is the idler you need which is a pretty standard part
http://ep.yimg.com/ca/I/buyitnow64_2165_12635595
you make a loop in the belt to get it in the pulley, thats why you don't have to remove the wheel, and it comes as one complete part
Jul 04, 2011 | Dryers
Hi. I have a Whirlpool dryer Model le5800xsw3. The drum stopped turning so I opened the front panel, thinking that the belt was broken. Turns out the belt was fine but the idler and pulley assembly...
The ***. has an edge that fits into a slot on the bottom .The other side goes into another slot.check the internet for your dryer belt config.
Sep 24, 2010 | Whirlpool Dryers
I'm changing the dryer belt and the Idler & Pulley assembly came off and I don't know where to reinstall it.
If the model number is correct, installing a new dryer belt for this dryer involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Roper and refer to diagram H.
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Jun 18, 2010 | Whirlpool LER5634L Electric Dryer
The pulley and brcket fell off it's position laying in the bottom of the dryer don't know how it goes ?
If you are referring to the tension pulley that keeps the belt tight on the drum, just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belts. A replacement pulley can be ordered on line at any of the following websites:
repairclinic.com
The part number is 691366 (if needed).
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 13, 2010 | Whirlpool Dryers
The belt fell off of the drum, i have the front off but i dont know where the disconnected pulley goes.
Unplug dryer or disconnect power.
Locate mounting slots in front of motor. (In some cabinets, there are two sets of slots for mounting the idler assembly. In this case, mount the idler assembly in the slots that line up under the grooves in the motor pulley.)
Install idler assembly into cabinet base by hooking mounting tab (A) into 1⁄4" wide mounting slots and setting mounting tabs (B) into the 3⁄16" wide mounting slot.
Make sure belt is around drum, with grooves down.
Route belt through the idler and around the motor pulley.
Sep 12, 2009 | Whirlpool Dryers
I have a Whirlpool gas dryer that buzzes when I turn it on and gets hot, but does not rotate.
The problem you describe sounds like a broken belt. The steps below outline how to check for that and disassemble if necessary.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
http://www.applianceaid.com/images/belt-config.JPG
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble. Good Luck
Sep 09, 2009 | Whirlpool LER5636P Electric Dryer
My whirlpool dryer heat up. But does not spin.
Belt and pulley configuration
Sep 06, 2009 | Whirlpool Dryers
Whirlpool dryer the belt has come off the pulley.
remove screws under lint screen ...press clips in at front corners of top and lift top remove 5/16 screws on inside top of front panel lift front off ck idler pulley if is roller type just reinstall loop belt from left and push through idler bracket and over motor pulley..bracket fits in slots in base if idler is glide type replace it with roller type 691366(i think)
Nov 15, 2008 | Whirlpool LER4634J Electric Dryer
I tryed fixing my kenmore dryer but the belt is loose and i found what looks like a half moon type of pully
If you are talking about the idler pulley, which isn't a pulley at all, it is highly recommended that you replace it with a standard idler pulley. This was orginally designed as an attempt to save money by the manufacturer, but turned out to cause premature belt wear in many cases. A replacement idler assembly (part number 691366) is a better option. As far as reinstalling the dryer belt, you can find diagrams at repairclinic.com under the "Special Features" section under "Repair Help". There is a link for "Dryer Belt Diagrams". Your dryer is manufactured by Whirlpool. Your diagram will be either "H" or "K" depending on how the dryer is constructed. If your dryer has a removeable back panel, use "H". If dryer does not have a removeable back panel, use "K". HINT: Most dryers with removeable backs have the lint screen on the top of the dryer. If you need additional assistance, please post back and let me know. I hope this helps you.
Jul 23, 2008 | Dryers
Dryers Logo
678 people viewed this question
Top Dryers Experts
