Question about Samsung SC-D353 Mini DV Digital Camcorder
Pink and white lines is all that will show up when I try to record or play back
I have only used this camera 8-9 times and the flip out screen you look through to see what you are recording has pink and white lines. It will do the same thing when I try to play back what can I do to fix this.
  • 1 more comment
  • d8thnote Aug 11, 2008
    I don't have pink and white lines but I do have green lines. I cleaned with a head cleaner and still the same problem.
  • dienas1234 Aug 27, 2008
    PINK and whitle lines when I try to record of play back. Also this happens when I try to take picture with the memory card
  • Mikhail Ivanin
    Mikhail Ivanin Sep 27, 2008
    i have 5 green stripe in lcd when i useplayer mode
    Champion:
  • 217 Answers
Right.. it is not a video ribbon, they call it flexible wires or flexwire in short..
Sorry you need profesional service
Posted on Oct 08, 2008
    Problem Solver:
  • 10 Answers
Video ribbon needs to be replaced
Posted on Aug 30, 2008
SOURCE:
Canon 80D operates as normal except all shots taken are white with a wide pink band running across the screen. Camera plays back old shots on card normally but all new shots are just pink and white.
Sounds like your imaging sensor has failed and is not recording blue or green tones. Take your camera to a good camera store or send it to Canon for a service estimate.
Apr 07, 2018 | Canon Cameras
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
My Sony Camera screen when i turn it on is white & has a pink line going diagonally through the screen
A multicolor vertical line may display on the camera LCD screen if there is glare on the subject being photographed. Avoid photographing very shiny surfaces that reflect excessive amount of light into the camera lens. Follow the procedure below to resolve this issue:
  1. Record the video or click the still pictures in a different lighting environment.
  2. On the camera, move the FOCUS AUTO/MANUAL switch to AUTO .
  3. Set the PLAY/STILL/MOVIE selector to MOVIE or STILL .
  4. Press the WHITE BALANCE button until the white balance is set to AUTO (no indicator).
  5. Record the video to new media.
  6. NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required.
Aug 13, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Flip Camera Video Screen is white
buy a new one take the screen out of the new one and then swap screens take it back to walmart tell them it doesnt work and get your money back.
i would just say swap cameras but im sure theres serial numbers in these
Oct 07, 2008 | Pure Digital Flip Video Ultra Camcorder
Please please HElP me
the video ribbon inside the camera is torn it is very common with the camera i have one used it maybe 24 times and the lcd screen went from fuzzy to white with lines in it to blank. very common problem with the camera.
Jul 31, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Help With My Digital Video Camera!
You try it with proper connection using a new or working wire if you have used a vcr to play back.
Play the tape with any other camera.Bcoz your monitor may be fault.
Play the head cleaning tape in the camera, and try
May be the recording head of your camera is clogged
Mar 29, 2008 | Photography
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Pink or grey horizontal lines on video download or viewing
I have the same issue and have for over a year (haven't had the time to send it to Canon for a few weeks to analyze, but have cleaned it numerous times). But I can tell you that the problem is internittent and the recordings are fine. Eventually, don't know the remedy, but it will suddenly stop doing that and I can download fine, and watch on camera fine. When it does happen, I just keep recording. It never shows up permanently. I re-tyr downloading or viewing and about the 3rd or 3th time (let it sit for a few hours between) it is normal!
Oct 09, 2007 | Canon ZR90 Mini DV Digital Camcorder
Pink strips through screen and tv when playing back tapes
clean the heads - the '5 stripes' are the symptom of dirty heads.
May 16, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
200 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
