Question about Maytag Dishwashers
The dishwasher works fine but the jet dry doesn't seem to release to clear dishes. I have cleaned it out and put new liquid in. It always seems to be a the same level and never needs refill. Glasses are cloudy There is nothing in the book on how to help the drying agent to release. the dial even at MORE does not help
  • 4,323 Answers
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Posted on Apr 02, 2011
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
Good morning, I have a GE dishwasher and lately
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 29, 2011 | GE 24-7/8" Convertible Portable Dishwasher...
New dishwasher...The Rinse Aid doesn't seem to be putting out any liquid. (How is it supposed to work?) Plus, dishes don't seem to be coming out as clean as expected. In your opinion what is the...
You won't see any liquid it comes out and gets rinsed off during the last wash cycle.As for detergant I think your best bet is to use the tablets. Like the three and one "Finnish " Hope this helps.
Jun 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
We have put jet dry and changed soaps but it always leaves a white film on the dishes! No other appliances have problems with this in the house.
Thanks for your question. You may have a couple of problems, first if you are using jet dry it is a surfactant. Which means that it places a small amount of a chemical on you dishes to keep them from spotting. If your dishwasher is releasing to much this will cause a white coating on dishes. In the loading area for you jet dry or liquid spot rinse there should be a knob that is marked from 1-5 or so. First turn this dial all the way down to 1. This will reduce the amount of jet dry released. Then monitor the amount of jet dry that you are going through. You should be able to get about 60 loads from a small bottle of jet dry. The other problem may be that you have washed a item that was not dishwasher safe, like a plastic bowl or such. Some of these items will leech the pigment into your dishwasher and then onto you dishes.
I might suggest that you purchase some dishwasher cleaner from you local Store. Walmart and most box stores carry this in the same section that you purchase your detergent. You will need to empty the dishwasher, following the instructions on the cleaner insert into your dishwasher. Then run it through a complete cycle. After attempting these items please let me know if you still have an issue, but I am almost certain that you will have corrected the problem. Thanks D.R. Wilkins
Nov 05, 2010 | Dishwashers
My Whirlpool Gold, Quiet model III is not rinsing or drying well. My dishes don't seem clean and there is always diswhashing liquid still in the distribution cup.
the problem that you have is with your water temp not being right to break down the soap and clean your dishes. also you have to fill completely jet dry compartment,very very important for cleaning,drying,and the spots. turn your water on and let it get hot b4 you start the unit . once the water is hot then start the machine. you will see a big difference. send me a 4 thumbs up post if it works
Feb 27, 2010 | Dishwashers
Can I take the bottom part of the dishwaher apart
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Jan 31, 2010 | Kenmore 15762 Dishwasher
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
177 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
