Question about Saeco Magic De Luxe Espresso Machine
INSIDE BOX THAT HOLDS THE USED GROUNDS....CAN'T GET IT BACK IN....SMALL PIECE OF PLASTIC KEEPS IT FROM MOVING INTO PLACE. SAECO ITALIA...
  • 515 Answers
If you look where the dregbox will fit, you see a hole. Take a screw driver and hold the little plastic pin when you close the door and power on the machine. When the machine not get any noise then you can put in dregsbox again.
Hope this will help you.
/Mirran
Posted on Aug 05, 2008
SOURCE:
Miele CVA 4070 dispensing unit leaking
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, they're made from the same plastic used in football helmets.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W," with the "wings" pointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," wait for it to go through its warm-up and display No F73 message.
Hope this helps
David
Dec 10, 2017 | Miele Coffee Makers & Espresso Machines
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
I notice I have to empty the grounds drawer more often because there seems to be more water coming into the drawer with the used pucks when they drop. Before I would empty it after about twelve pucks, now...
Hi
There is a small knob in the bean hopper. It sounds like it is all the way to the minus. Turn it back towards the plus(+) then back 1 mark. Then try again. It could also be a stripped thumbscrew that pushes up and allows the coffee to fill the head and dredge drawer. See if there is any water in the top of the brew unit where the thumb screw is? The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that's the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it's a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Apr 22, 2011 | Starbucks Saeco Italia Digital Barista...
I have a Saeco Italia Digital Barista and we've used it for years every day and loved it. Unfortunately, it has started leaking water inside and dripping out under the machine I've tried descaling,...
Its probably a loose hose or a failed O ring. You can take it apart and probably find the problem and fix it if you are handy. As it is don't use it. It's dangerous. You cold get a shock. Unplug it and either repair it or take it in to someone who handles Saeco. Their website lists repair facilities.
Jan 17, 2011 | Starbucks Saeco Italia Digital Barista...
HELP - two ball bearings in grounds hatch
These two litle wandering critters could be check balls to prevent some kind of back flow. How is the unit working?
Nov 09, 2009 | Starbucks Saeco Italia Digital Barista...
I have a Saeco 21103 unit and it keeps getting an error message of ''dregdraw Miss'' what is that?
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Oct 27, 2009 | Coffee Makers & Espresso Machines
Water leaking from steam hose on Saeco Italia
There is a part that the hose connects to and it is made of plastic. The plastic on mine had a tiny split in, which caused it to leak. I got a replacement one made of brass and that problem is fixed. Now my machine is broken in another way and I am hoping to get it fixed. What a piece of junk!!!
Aug 05, 2009 | Starbucks Saeco Italia Digital Barista...
I can't get the coffee grounds plastic dispenser back into the
remove the used grounds container and place a folded piece of paper where the grounds container touches the micro switch ( that is in a slot in the left side where the container enters approx 8cm inside) and then restart the machine and the grounds container will now be able to enter, remember to remove the folded paper before inserting the container
Nov 18, 2008 | Saeco Vienna Deluxe
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Saeco Italia sensor problem
It does that after about 8 rounds of brewing, and it doesn't matter if you empty the grounds after every brew or not. It's automatic.
Sep 16, 2007 | Starbucks Saeco Italia Digital Barista...
Saeco Magic De Luxe Espresso Machine Logo
35 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
