Question about Magic Chef CYG2000AWW Gas Dryer
The dryer runs. after 20 minutes or so stops. i think themotor is getting hot because there is too much load on it maybe the rollers are too sticky?
    President:
  • 3,074 Answers
Disconnect vent and run dryer, as it sounds as though the vent is restricted. Hope this helps Tim
Posted on Apr 02, 2011
Whirlpool duet sport dryer stopped running after 20 minutes into a 40 minute cycle on hot.
Check for clogged vent. Vents will clog midway and if vented to the outside of a house, there is a plastic cover that usually gets covered with lint that gets wet and dries to a hard mask.
Feb 02, 2017 | Whirlpool Dryers
Kenmore king size capacity 90 series
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Jan 06, 2008 | Kenmore 63942 Dryer
I have the heavy duty 4 cycle Amana dryer. When I turn it on it is very loud and stops after about 20 minutes. It smells really hot so maybe it's overheating? But why?
sounds like motor bearings are failing. causes motor to overheat and cut out on motor protector. I'm afraid a new motor is in order.
Jun 15, 2010 | Amana DLE330RAW Electric Dryer
My dryer a Whirlpool. will run for about 10 to 20 minutes, then cuts off. After about 10 to 20 minutes, I can start the dryer again (push start button) and it will run for another 10-20 minutes. ....This...
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Apr 30, 2010 | Whirlpool LER4634J Electric Dryer
I have a samsung DV337AEG/XAA Electric Dryer which three weeks stopped heating up. We replaced the heating element, along with the thermostat. after that it heated up for 20 minutes then stopped, replaced...
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Mar 25, 2010 | Samsung Dryers
Motor shuts off, and resets after a few minutes dryer wont run
May be the tub support rollers, If this is problem you will have to remove the tub. Then check rollers to see if they turn free. If not replace the faulty ones. This drag on the motor will cause it to get hot.
Mar 29, 2009 | GE DBXR463EDWW Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 | Dryers
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Magic Chef CYG2000AWW Gas Dryer Logo
77 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Charles T Nevin
Charles T Nevin
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
