We have a Bompani BO 5267 E washer/drier and the shortest programme we can find lasts 1 hour and 20 minutes (programme 14) - even with a half load. Is there a shorter programme for just usual everyday cotton washes - or an eco wash? Thanks
  • 209 Answers
SOURCE: aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Posted on Sep 14, 2007
SOURCE: beko AA class washing machine 1000rpm WMA 510W
you put it on a 40 degree on the other side on the top left hand side i had the same problem for ages i couldnt help but laugh when i seen this
Posted on Jan 19, 2009
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
SOURCE: i need an english manual
no power at all.even the door is close
Posted on Feb 15, 2011
  • 6277 Answers
SOURCE: Dear Mr or Mrs, I am
Hi Harri from retired Englishman in SW France,
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Sep 06, 2011
I need the manual for Bompani Antilla BO 02014. Can anyone help?
Try Googling (Bompani Antilla)(BO 02014)(manual) without parens.
May 10, 2017 | The Computers & Internet
Bompani microwave oven bo 23dgs user guide
i Need a User Manuale for the Bompani micrwave oven bo 23dgs
Aug 06, 2012 | Microwave Ovens
I need a user manual for bompani bo 02727 washer machine
Sir,
i have a bompani W/M BO 02727
can i hav manual- i dont know how to operate proper?
Jan 03, 2011 | Washing Machines
The washer is working ,but the wash cycles even on the shortest cycle take over 1and a half hours.
Your timer must be on the way out. You could try to oil it. To get it out you need to use some tweasers to remove the knob retainer:05a9706.jpg
Oct 28, 2010 | Hotpoint VBXR1090B Top Load Washer
How long does the soak programme last?
For this machine the length of time of between 30 minutes and 2 hours can be programmed in 30 minute increments for the soak process.
The machine is set ex works with a soak period of 2 hours.
To programme in a different soak period see "Programmable functions - Soak" in your user manual. See Page 59.
Oct 16, 2009 | Miele Novotronic Premier 500 Front Load...
At 20 minutes the drawer leaks
have you removed the drawer and cleaned the soap drawer holder ? as these can be blocked and cause this fault
Sep 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Bosch WFMC3200UC/01
Try cutting the amount of soap you use in half. If we use the detergent manufacturer's recommended amount (yes, we are using HE type detergents), suds remain and require additional rinse time or cycles, taking a long time. We cut the HE detergent in half and the times got pretty accurate and the clothes still came just as clean. Hope this helps you!
Apr 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
