Question about Indesit IS70C Electric Dryer
It leaks from the front, I have cleaned the filter and the removable condensor thing has been cleaned on a regular basis
    President:
  • 3,074 Answers
Sounds as though the drain tube is starting to clog, remove the condenser tank, and remove the drain tube and clean out. Good Luck Tim
Posted on Apr 02, 2011
Ctd80 hotpoint dryer panel flashing dryer not working
Filter at bottom of machine needs pulling out and cleaned on a regular basis. This is a common fault and the lights is telling you to clean the filter. It is a large filter that unclips at the bottom front of machine. Remove two small screws from the front of the filter located left and right and gently remove the front plate. Once removed you will see a metal filter clogged with clothing debris. Clean with cotton buds and a damp cloth till clean. replace all parts and you should have it working once again with a good heat source as well. Every 2-3 months is sufficient to keep it cleaned. Hope this helps.
Feb 27, 2014 | Hotpoint Dryers
Thumble dryer not working
Filter at bottom of machine needs pulling out and cleaned on a regular basis. This is a common fault and the lights is telling you to clean the filter. It is a large filter that unclips at the bottom front of machine. Remove two amall screws from the front of the filter located left and right and gently remove the front plate. Once removed you will see a metal filter clogged with clothing debris. Clean with cotton buds and a damp cloth till clean. replace all parts and you should have it working once again with a good heat source as well. Every 2-3 months is sufficient to keep it cleaned. Hope this helps.
Dec 21, 2011 | Dryers
Water leaks on floor from my p25 washer.
This is a common problem with Malber. On the lower right hand corner, there's a door with a lint filter. This filter needs to be cleaned on a regular basis. Be careful when removing the filter. It has a large rubber gasket that expands when it's installed and tightened and will offer some resistance when removing. When the filter becomes clogged, water backs up and forces it's way out through the filter.
Aug 31, 2011 | Malber P25 Front Load Washer
Our machine smells like a wet dog what can we do to freshen it up
Cleaning the air intake filter is a good start, as well as cleaning it on a regular basis. If you like stick a laundry softener sheet near the air intake on the front of the unit. But, do not attach it to the unit.
Hope this helps freshen things up. Thanks for choosing FixYa.
Aug 23, 2011 | Heating & Cooling
My front loader flashes f- and wont finish the cycle why?
Sorry but I do not know your particular washer but I am guessing at one thing it might be.
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and the motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP ANY WATER!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Hope this is the problem and good luck!
John C
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
I just purchased a whirlpool side by side fridge, the salesman could not answer my question, I wanted to know if these have self cleaning condensor's on them
Good day,
There is no such thing as a self cleaning condenser.
The condenser is the black coil assembly, located at the very bottom of the refrigerator.
It is a great dirt and dust collector and must be cleaned on a regular basis, once or twice a year by hand, using a vacuum cleaner with a crevice tool attachment or by blowing out with a tank and hose of compressed air.
The second procedure is by far the better, but also messy.
Nov 09, 2009 | Refrigerators
Water leaking from the pump area
you have to completely remove the filter. twist and shake it until you remove it fully. when removed clean filter thoroughly, also use a long nosed pliers to remove any coins etc from filter aperature. clean the filter regularly
Dec 20, 2008 | Bosch Washing Machines
Leaking
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
Aug 06, 2008 | Miele Novotronic Premier 500 Front Load...
Indesit IS70C Electric Dryer Logo
267 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
