Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Posted on Apr 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer will not come on. The Control Locked light is on. In the manuel I see that it describes what it is but does not give any solutions. What do I do?
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on Apr 02, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
824412
Points
9577
Http://www.ehow.com/how_5636257_unlock-whirlpool-dryer.html
Control locked light is on front panel dryer locked up need to know how to get unlocked
The following link explains how to unlock the control panel on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is a designed safety feature of the washer that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can be inadvertently locked by leaning on the control panel, or during power outages. The instructions are printed on the front panel of the washer and are included in the owner's manual.
If the washer door remains locked, you can use the manual release to open the door. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If these steps do not provide you with a solution, you may have a more serious problem than simple operator intervention. Please let me know if you require additional assistance. I hope this helps you.
2answers
The panel light says control locked
Some dyers have a cool down safety feature
could be activated or could be a broken belt
check for a broken belt also
tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
Control lock on
To enable the Control Locked feature when dryer is
running:
Press and hold the CYCLE END SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.
 When the dryer is off, it is not necessary to press the Control
On button before activating the Control Locked feature.
To unlock:
Press and hold the CYCLE END SIGNAL button for 3 seconds to
turn this feature off.
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Off button, but can’t be
2helpful
How do you turn off the control locked key?
running:
Press and hold the END OF CYCLE SIGNAL button for
3 seconds. The control is locked when a single beep is heard and
the Control Locked status light is on.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
to turn this feature off.
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
1helpful
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
running:
To unlock:
Here is a manual.
I'm getting an E1 signal from dryer...What is the
This usually works to unlock the E1 code
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal buttonfor 3 seconds to turn this feature off.
Locked light is on, the dryer can be stopped by
If this worked for you don't forget to give me a ranking. Thank you!
2answers
Whirlpool Dryer GGW9200LW1
this is your child lock
look in your manual how to unlock
Control Panel
check your owners manuel should tell you how to un lock controls wont be an obvious button as its a safety feature
3helpful
2answers
Dryer problem
Here is the link to the owner's manuals etc. if you need it; http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GGW9250PL&siteCode=WHRCOM Check the first owner's manual, page 14. It says; " Control Lock. This feature allows you to lock your settings to prevent unintended use of the dryer. You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation. To enable the Control Locked feature when dryer is running: Press and hold the END OF CYCLE SIGNAL button for3 seconds. The control is locked when a single beep is heard and the Control Locked status light is on. When the dryer is off, it is not necessary to press the Control On button before activating the Control Locked feature. To unlock: Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off. NOTE: When the dryer is running and Control Locked is on, the dryer can be stopped by pressing the Pause/Cancel button, but can?t be restarted until the control is unlocked." Hope this helps :)
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
