Question about Panasonic Lumix DMC-TZ3 Digital Camera
Bought brand new lumix gone to charge battery and it is green light when i put it in but when put in camera it starts up and then flashes to indicate empty battery
    Brigadier General:
  • 11,967 Answers
This camera is never going to make you happy....return it immediately.
Posted on Apr 02, 2011
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
My Panasonic Lumix DMC-FZ28 will not power on, although the battery has been charged.
More than one possibility can cause this. Your battery can be on the end of life. Only when the battery works in another camera, of the same model, you can check the capacity. Or with a multimeter, but you must have some electronic skills. Then the contacts on both the battery and in the camera can be dirty or oxidised. Sometimes users manage to put in a battery the wrong way around. This should be virtually impossible with your camera. Try cleaning the contacts in the camera and on the battery, using some cotton swabs. Never use anything sharp.
Then again try charging the battery. Look if the charger light starts green. And is it stops after some time. If you already charged the battery, it could be the light goes out after a few minutes.
If the charger light starts flashing, you know something is wrong with the battery to the connectors. Don't forget to close the battery cover correct. There is a switch, and if the door is not locked correct this switch still indicates open battery door and the camera won't switch on. Check your manual page 17 and 18.
Apr 17, 2014 | Panasonic Lumix DMC-FZ28 Digital Camera
My battery charger stopped charging the battery. Whenever I put the battery in the charger the green light flashes signaling a problem. I tried wiping the contacts as the book suggested but with no...
How long do you have the camera?
Rechargeable batteries don't last forever, and when they are too weak to take a charge, the little light just blinks.
They could also be shorted out.
This flasing is a problem code. "The book" should also tell you what these flashes mean, although it usually means: replace the battery.
Jun 24, 2011 | Panasonic LUMIX DMCTS2 / DMCFT2 Digital...
Hi there...I had not used my Hoveround MPV4 scooter for over a year and when I finally went to use it, the batteries were no good any longer as they would not hold a charge...so I just bought two brand new...
Hi Pam,
The new batteries should work right away. (Your old ones had gone solid from sitting for so long- charge the new ones at least once a week to keep that from happening, even if you are not using your power chair.)
You may want to check all of the connections to make sure they are tight especially on the battery posts, also make sure the fuses are not burned out. It's recommended to run the new batteries into the red (fully discharge) then let them charge for 8-12 hours to make sure the batteries get a full charge the first time out, but if you haven't done that, it should not cause any flashing lights.
You said that green lights were flashing (assuming on the controller); if all 10 bars (3 red, 4 yellow, 3 green) are flashing that indicates a poor battery connection. 9 bars means you need to do a brake reset. Check page 51 of your manual for controller light codes or check this link: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
If you have any other concerns, let me know. Good luck!
Oct 12, 2010 | Health & Beauty
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Green LED is on = Carging is complete
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
133 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
