Question about HP Officejet 5610 All-In-One InkJet Printer
I just purchased remanufactured ink cartridges for my hp 5610. I usually buy the #27 but switched to the #56 and the printer says it is not the correct cartridge. I doubled checked it is the correct number. Is there a way around this since I know it is the correct one?
    Scholar:
  • 111 Answers
Try to take out the cartridge.
Make sure that you have removed the pink tape from the cartridge (Nozzle protective tape)
Try to clean it with the clean cloth or paper napkin
and then Re seat it
=============================If this does not help ==============
Try to check with old 27 cartridge and if you don't get any error with 27 that means that there is some problem in the new cartridge itself
Posted on Apr 02, 2011
Printhead moves but does not print
If the HP 56, 57 or 58 ink cartridge refuses to print or function at all (i.e. blinking ink light on Deskjet 5000, 5100, 5500, 5600 or 5800 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the cartridge nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Also, verify the top cover is closing properly (it has an interlock). If necessary create a small shim and press into the top-right port to close the switch (i.e. use a piece of cardboard or fold a post-it note 10x to form a small/hard shim about 1/4 inch by 1 inch in size). This should allow the printer to properly energize and the blinking lights should go away.
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
Apr 15, 2013 | HP DeskJet 5650 InkJet Printer
HP DESKJET 5600 ENCOUNTERED ERROR WHEN POWERED ON
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or fails to function at all (i.e. blinking ink lights on Deskjet 5000, 5100, 5500, 5600 or 5800 series printers) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
Also verify that the cover interlock switch (at top-right side of printer) is closing properly - you may need to place a thick shim (1/4 inch by 1 inch) into the door switch port to enable printer to properly energize (I would check this first). This Deskjet printer series is known to have a top cover closing issue (the top covers warp over time unfortunately).
Jun 19, 2012 | HP Office Equipment & Supplies
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
What numbers of cartridges for 5610 all in one?
for black hp 27 (10 ml ink) or hp 56 (19 ml ink)
and color hp 22
Oct 17, 2010 | HP Officejet 5610 All-In-One InkJet...
Will 27 work on 4215
HP 27 cartridge is not compatable for this printer. Supported cartridges are :
Back : HP 56
Color : HP 57 , HP 28
Photo cart : HP 58
May 08, 2010 | HP Officejet 4215 All-in-One Color Photo...
Purchased cartridges for the HP all-in-one 4215xi printer and cannot install the cartridges. 1st I purchased the 56/57 tri-pack and couldn't get them in the printer. Went back and purchased 27/28...
Your printer takes the HP 56/57 cartridges. When you buy new cartridges you need to remove the black clip, then remove the strip of tape that covers the print head, then the cartridge can be installed in the printer.
Mar 22, 2009 | HP OfficeJet 4215 All-In-One InkJet...
5610 all in one cartridge error "see troubleshooting"???
Please let me know what is the exact error message you get on the printer screen.
and also let me know which cartridges you are using.
the cartridges you need to use are HP Black : 27 or 56
HP Tri color cartridge : 22 and 58
Jan 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Misrepresented product?
No manufacturing process is flawless. These things happen. Return to staples for an exchange. Most managers will exchange ink even after the 14 days. If they dont, then buy new ones and recycle the nonworking ones for $3 on your rewards statement. I have seen people come back the same day after they bought a brand new HP ink cartrige beucase it does not work. Its not that they had the wrong cartridge, its just that it was a bad one.
Dec 07, 2007 | HP 56&57 Inkjet Cartridge Combo 3-pack...
Printer goes throught the motions of printing, but what comes out is a clean page - no ink
I had the same issue when I replaced the printer and kept the old cartridges I had just purchased. The OK button I pressed was on the PRINTER not the PC. You dont say the model printer you have. Mine is an all-in-one J6480.
Oct 24, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
