Question about Goodman Heating & Cooling
We need to change the heat exchanger for my Goodman Heat Furnace model no.-GMP 075-3
  • 1,420 Answers
Not an easy task! Take many pictures as well as draw out and mark which wire went where. You will have to remove everything from inside the cabinet to get to the heat exchanger. It may be easier to replace the furnace. If you are paying a professional to do the exchange, figure three hours if they have done it before, if not figure 5 to 6.
Posted on Apr 02, 2011
Janitrol gas furnace gmp 075-3 ,ignitor lites but pilot nor heat will go on
Check out pressure switch , check hoses are tight and not split , check air filter is clean jump out pressure switch and see iif it lights .
Jan 10, 2013 | Heating & Cooling
I have a Goodman GMP 075-3 Rev B and cannot find the filter to replace it can you tell me where it is
I have the EXACT same problem. Cant find the filter and no manual came wit hthe furnace when I bought hte house!!! AGH!!
Nov 08, 2010 | Goodman GMS90703BXA Heater
I have a goodman gmnt 100 b furnace 2 stage when the gave valve turns on and floods the heat exchanger with flame then the squirl cage fan turns on and i loose the the flame
If you are getting flame distortion when the blower comes on it usually means a cracked heat exchanger which can lead to carbon monoxide, get your furnace checked by a qualified tech..
Jan 31, 2010 | Goodman Furnace Draft Inducer Blower ...
How to change fan speed on a goodman gmp 100-3 furnace
Usually you can find the control board on the lower part of the furnace. Turn the power off and remove the
doors. This board is usually located directly in front of the blower motor.
On the control board locate the terminals marked heat/cool/park and Park Lets say the Heat Terminal
has a red wire attached to it and you want a higher
speed.
Red is uasually low speed, remover the red wire from
heat terminal and exchange it with a wire attached to
a terminal lab eled park. Black is usually high spped
Jan 01, 2010 | Goodman GMS90703BXA Heater
Goodman furnace\ blower comes on,unasked
Sounds like the fan switch on the furnace is set to low. Turn power off to furnace, take door off of furnace look for a fan switch, it may be a fan - limit together. The limit settings should be approximately 160° to 200°, and the fan settings should be about 100° to 140° set it to 120° it it's already set there then you probably need to replace it.
Aug 03, 2009 | Heating & Cooling
Twinning problem
Switch the leads and also make sure that you have a good ground.
Mar 30, 2009 | Goodman Heating & Cooling
Support on changing out the heat exchanger on gmnt 080
1st, take a picture of where each wire goes to. Look in the owners manual for an exploded view of how it goes together. The heat exchanger most likely comes out from the front of the furnace. You will have to remove and reinstall every componant inside the furnace to get it out. Suggestion, replace the whole furnace. It will be cheaper.
Sep 18, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
344 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
