Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
My dads Jazzy 600 got wet and now wont do anything. no lights at all. what can I do- he needs it daily and we are on fixed income?
  • 692 Answers
If medicare paid for Dad's chair then contact Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare didn't pay for Dad's chair then the cost of a refurbed joystick is still very high about $700 and if the joystick got wet then he'll need a new or refurbed one. Sorry Hope this helps
Posted on Apr 02, 2011
I have 3 red 4 yellow and 1 green, also the speed lights flash only once .
Hi ring this number they might b able to help with youre problem ,,1-800-800-8586.... Cheers
Aug 29, 2016 | Pride Jazzy 600 JAZZY 600
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
How do I replace the throttle potentiometer and what s the approximate cost?
You would need to remove both covers top and bottom of the console holding the throttle pot. Typically, there are 4 or six screws holding the covers. The throttle pot is attached with 2 screws and has 1 electrical plug. The throttle lever on the end of the throttle pot shaft usually is held on with 2 Allen wrench set screws.
Before replacing the part it can be tested using a digital voltmeter.(procedure is described elsewhere).
Obtain the correct replacement part by searching by Model and serial number and part description. The manufacturer website is a good starting point for parts
Jan 18, 2016 | Pride Jazzy 600 JAZZY 600
My flash code is SEVEN PAUSE SEVEN which indicates JOYSTICK FAULT.
PDF]INFINFB2043_Jazzy_600-600XL_Troubleshooting_Rev B ...
www.pridemobility.com/download.php?...Jazzy_600-600...
Pride MobilityWhat if the systems on my Jazzy 600/Jazzy 600XL seem to be "dead" (controller does not ... Each controller will flash a code via the battery ... 7. Joystick error. Contact your authorized Pride Provider. Four yellow LEDs ... This is indicated by the VR2/VSI speed ... flash in a numbered sequence followed by a 2-second pause
Pulls to the right and stops and wont go and the control lights flash on and off
What are number of lights and colors? Check motor connections to controller. Is it freewheeling?
Mar 16, 2013 | Pride New Jazzy 600 Power Wheelchair by...
My father has a Jazzy 600 electric wheelchair and it has been working fine, batteries are only a few months old but all of a sudden it will not charge. Should not be able to move the chair while it is...
Sounds like the inhibit function of the chair has been damaged. This function will not let you move the chair while charging. If Dad doesn't have the charger off when plugging in to the chair or removing it it can short out the charger port causing your problem. Unfortunately the only fix is to replace the joystick/controller. If Medicare paid for Dad's chair then they will pay for most of the repair costs. Contact the provider that brought Dad's chair and ask if they can order a new joystick for you Hope this helps
Jun 06, 2011 | Health & Beauty
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Dec 20, 2010 | Pride New Jazzy 600 Power Wheelchair by...
Replaced battery in jazzy 600 wheelchair and the light comes on, but wheelchair will not do anything.
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
Sep 09, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
116 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
