Question about KitchenAid KUDI24SE Built-in Dishwasher
Trying to locate upper arm fill tube that goes into spray arm. it is totally deteriorated. model kudi24se about 12years old.
  • KitchenAid Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on Apr 02, 2011
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
Motor runs but
Do you have a print manual for this unit?
Aug 05, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
How do I get the upper rack arm back on the rollers?
The back endcap on the slider has snaplocks that has to be squeezed then pull off. This should allow you to pull the slider out and then guild it back over the rollers and into its proper place. Just had to do this, and it's hard to get to with the door down, but can be done.
Jan 13, 2015 | Dishwashers
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Upper spray arm fell off, can not repair nor find part
I had the same problem, but was able to find the replacement part at http://www.partselect.com/shipping.aspx. My old arm also has the number 1544681 on it. If needed use model number PLD2855RFC1 to locate the same part. Good luck!
Mar 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Figidare dishwasher
It seems other posts were correct - The upper arm doesn't spin all the time. Once I learned that, and let the dishwasher cycle through, I saw that the upper arm does spin. So, there wasn't a problem with the upper arm afterall. That doesn't solve my crusty dishes problem, but that may have something to do with the soap we're using. We're going to try changing that next.
Dec 27, 2008 | Dishwashers
Upper spray arm is not turning round even though water is coming through. We have checked the internal system for blockages and the machine is filling / draining as normal. When a full programme is run,...
I found the problem to be neither blockages of the upper arm or roof spray arm or the upper basket arm hitting the the back of the dishwasher. the problem was that the pump inlet where the food scraps are macerated was blocked with all manner of gunge including small chicken bones plastic and other detritus. Removal of the macerator housing under the upper filter housing using 2 different sizes of torx driver easily fixed the problem. Probably why the upper dish rack cleaning degraded overtime, Directly proportional to the amount of detritus blocking the intake screen behind the macerator.17a8801.jpgb9e8fa8.jpg789f2b8.jpgfb7a626.jpgator. See pics
Jul 13, 2008 | Dishwashers
Rinse arms not spinning
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 10, 2008 | Dishwashers
Water not spraying hard enough
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Sep 30, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Dishwashers Logo
59 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
