Question about Whirlpool Dishwashers
Dishes are often dirty and glasses are cloudy even though they are rinsed before they go into the dishwasher
  • Whirlpool Master
  • 43,501 Answers
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Posted on Apr 02, 2011
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool Dishwasher---All Dishes Finish With Cloudy Film
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 12, 2010 | Whirlpool 24 in. DU930PWP Built-in...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Clear glass dishes are cloudy. What is causing it? We have checked the arms--they seem to be working fine. Some days it does better than others--today they were extremely cloudy. I washed the glasses by...
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is due to hard water deposits; make sure the salt reservoir is topped up. Do not worry about over-filling it.
If the cloudiness is not removed, it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. Dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Dec 17, 2009 | Dishwashers
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
Cloudy glasses
the problem is hard water. there is new product at www.dishwasherfilter.com that is guaranteed to solve this. it filters the water going into your dishwasher reducing the hard minerals and leaving your dishes spot free everytime. you will be amazed. it is very affordable. www.dishwasherfilter.com
Mar 28, 2009 | KitchenAid Dishwashers
Cloudy glassware, stained flatware
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 19, 2009 | Maytag 24 in. DWB1000 Built-in Dishwasher
Cloudy dishes after wash
We have had a similar problem (suburb of Pittsburgh, Pa.) and it is caused by hard water which is a result of drought conditions. I went to my local hardware store and purchased a product which I put in the dishwasher and ran through regular cycle. Glasses were much better, though as long as we continue with the hard water problem it is only a temporary solution.
Oct 18, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Not draining properly, leaving film, debris, & soap, draining through air gap
you wont get clean results if loading a dishwasher up with dirty plates, the food debris will circulate around with the water and keep reistating itself on the plates- as it may not get through the filters. try a powder wash with rinse aid topped up and the most important thing is that the salt bottle is topped up. you may also want to check that the spray arms are not all blocked up with debris.
Jun 03, 2007 | GE 24 in. GSD2120C Built-in Dishwasher
Dishwashers Logo
345 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
