Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Where can I find the repair manual for the Progressive Bagless Upright Inteliclean Vacuum, purple?
  • 7 Answers
SOURCE: Kenmore Progressive 36932 Upright Vacuum
It's located inside the vacuum kind of behind the where the dirt is collected. You can open and clean but this is probably not necessary. You probably vacuum very fine dust that is hard to remove from the system.
Try replacing or cleaning all filters and letting the vaccum run for a few minutes without moving. Agitator off of course.
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: i have a kenmore upright progressive beltless
Remove the belt from your beltless vacuum and you should be golden!
Posted on Jul 25, 2009
  • 5 Answers
SOURCE: i need to take apart my Kenmore Progressive
What problem are you trying to fix? The is no belt so you don't need to remove the bottom plate. If you are trying to remove the main hose, remove 4 screws on the back and remove the plate. There are 2 more screws under that.
Posted on Sep 07, 2009
  • 4 Answers
SOURCE: Kenmore progressive upright, beltless vacuum, the
They usually have belts for that kind of thing at walmart!
Posted on Oct 26, 2009
  • 715 Answers
SOURCE: The brush isn't turning on my Kenmore progressive
replace the belt
Posted on Nov 05, 2009
Caught fridge of a blanket in vaccum. Turned off and remove object. Now beater bar does turn. How to fix?
Sounds like the belt either just slipped off, or is broken.
It's normal when the beater gets jammed.
Can you spin the beater easily?
Jun 24, 2011 | Kenmore Progressive Upright Vacuum with...
When I turn on the unit and push on the level that draws the "arm" back, it immediately shuts off. I return it to the upright position and turn it on again and repeat the process. Same thing...
seems like there is a short in the unit. it is extremely hard to find kenmore parts. i would probably just go out and buy a new vacuum. Kenmores arent worth fixing.
Mar 22, 2011 | Kenmore Progressive Upright Vacuum with...
Kenmore InteliClean 116.35923502 Two, I believe unrelated, problems. 1) The InteliClean sensor lights stay amber and red even when the machine is in the upright position and the suction line is...
I had the same problem with the amber inteliclean light continually on. I found the problem to be in the plastic housing that connects the suction hose to the back of the upright section. You have to remove three screws and gently pull the hose housing off the vacuum. Inside I found a hairy clump that was caught on the inside of the hose. The optical "dirt sensor" is just inside the fitting on the upright section. When dirt or other stuff blocks the optical path of the sensors, the amber light will illuminate. My vacuum had an uneven cut on the hose which caused a snag point for hair, dirt and debris. Once this was removed, the vacuum worked like new.
Regarding the roller, this unit has an integrated motor in the roller. I would guess that you will need to take it apart, and hopefully only clean it up. If you need bearings, that will likely be expensive.
Dec 24, 2010 | Kenmore Progressive Bagless Upright with...
Beater bar stopped working
Here is one of my Tips on the problem you are describing:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
If you have further questions, just let me know.
Good Luck!
Jim
Oct 10, 2010 | Kenmore Progressive Upright Vacuum with...
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive vacuum clogs continuosly
Try taking the bottom off and this will reveal if you have something clogging up the flexible tube. Just did this last night there was a ton of junk clogging the tube and I cleaned it all out and put it back together now it works fine. Seems like with the design of the vacuum this will always be a problem.
Dec 08, 2009 | Kenmore Progressive Bagless Upright with...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Bagless vacuum cleaner
Check down by the brush roll to see if the inlet is clogged. This type of problem usually means there is a clog. But you do have a year's warr. on this, if you can't figure it out, then take it a Sears repair shop.
Jan 15, 2008 | Kenmore Progressive Bagless Upright with...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
121 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
